Stalling
Stalling
After I put my jammer 5s in when the truck is warm and stopped and I throttle real hard and then let off it stalls. It starts right back up though with out a problem. Anyone experiece this. When its cold it good. Thanks,
Paul
Paul
try to let out of it easier, will cure the problem. Also help prevent turbo bark. The IP goes from sending loads of fuel to stoping flow when you let off fast, starves the injectors and stalls the motor out. Some people get it so bad with the bigger injectors you need to bleed the lines before restart.
