Stainless Steel Hx35/40
Old Jul 26, 2007 | 01:58 AM
Ph4tty's Avatar
Stainless Steel Hx35 or hx40
Stumbled across this and thought it'd post what little bit of info I have. You can have a stock turbo and a stainless housing Dunno if it'll bolt up to the downpipe =\
http://www.timsturbos.com/SSTurbine_...MHI_Inlet.html
Old Jul 26, 2007 | 10:19 AM
Need95-00CTD's Avatar
Gotta be for the import crowd I would assume...
Old Jul 26, 2007 | 04:32 PM
1stGen545's Avatar
Thats what the sight states. Its for a mitsu-junky. Also for new Holset but probbobly not for the 35 or 40.
Old Jul 26, 2007 | 10:00 PM
Ph4tty's Avatar
I wonder if Bullseye makes the stainless housings HTT is using
Old Jul 27, 2007 | 01:39 PM
kas83's Avatar
The applications pull down says HX 35 and HX 40.
Old Jul 27, 2007 | 02:19 PM
gman07's Avatar
It's probably a pretty small housing too (<9cm). You would have to make a backing plate with the V-band flange too.
Old Jul 27, 2007 | 02:30 PM
signature600's Avatar
Shhhhh...someone might hear you!
Last I knew, they were
Chris
Old Jul 27, 2007 | 03:46 PM
I wouldn't be so sure...a lot of the imports are running with the 12 and even 14cm housing, remeber most of these motors are running around 4500-6500 rpm in those jap cars, which is a lot of moving air, so they need big wastegates and big housings.
Old Jul 28, 2007 | 06:47 PM
Ph4tty's Avatar
hmm
http://www.bullseyepower.com/testdat...ieseltruck.asp
clifford
Nov 17, 2003 06:23 PM
Mar 25, 2003 02:23 PM
Dodgezilla
Mar 4, 2003 03:47 PM
dsljunkie
Jan 17, 2003 02:49 PM
