Stage 2's and chip or just stage 3's
Old Mar 7, 2007 | 04:04 PM
LUKE-MM-PULLER's Avatar
Today I put my stage 2 injectors in . While I'm happy with the power gain, I want more. So should I get a programer or order stage 3 tips now? I'm just looking for some advice.
Old Mar 7, 2007 | 05:01 PM
dieselrob's Avatar
I would go with a box. You have all the suporting mods done clutch fuel press gauges. It depends if you want to tap the pump wire or not. If you want to tap the pump wire an edge comp or the quad box that has 3 settings would be nice. If you want to stay away from tapping the pump, grab a smarty best non tapping fueling device you can get.
Old Mar 7, 2007 | 05:32 PM
I'd like a smarty but right now its a little to much money. are there any others that dont tap the pump wire
Old Mar 7, 2007 | 10:11 PM
Ph4tty's Avatar
Egde EZ and Van Aaken are both popular. Check the dtr classidieds =P
Basically anything that advertises around 60 hp gains doesn't tap the vp44.
Old Mar 8, 2007 | 11:02 AM
natlchamp2k4's Avatar
I would go for a box, not a programmer. a box will do boost fooling which you will need with the sticks. Just search the classifieds, you can find a us EZ or VA for $200.
Jamie
Old Mar 8, 2007 | 11:47 AM
CSAGrey1's Avatar
You've got an advantage over me that your a manual but with what I have listed in my sig it gets real toasty real quick. food for thought!
Old Mar 8, 2007 | 01:51 PM
Big Smoky's Avatar
I think you shoud for sure get a box next to get the full potential out of the injectors.
Old Mar 8, 2007 | 08:59 PM
Jamie
I already have a boost fooler, so I pretty much just need a box/programmer. And I absolutely dont want to tap the pump. Thanks for the suggestion, i do appreciate it.
gergthegreat
Dec 30, 2008 09:19 PM
bansh-eman
Jan 27, 2008 02:48 AM
Elk_Hunter
Oct 24, 2006 03:17 PM
cowdude
Feb 19, 2003 06:20 PM
