Stacks question?
Old Nov 18, 2006 | 05:57 PM
Brendan's Avatar
Question Stacks question?
When you guys put your stacks in did you cut through that little crossmember under the box, or set everything behind that?
Old Nov 18, 2006 | 06:13 PM
BigBlue's Avatar
I cut about half of that crossmember out.
Old Nov 18, 2006 | 07:41 PM
Brendan's Avatar
Okay, I only went through the flange. I thought I'd set them too far back but that extra inch wouldn't make too much difference.
Old Nov 18, 2006 | 09:10 PM
hump's Avatar
Brendan
I cut about 1/2 of the cross member out as well
Old Nov 19, 2006 | 03:38 PM
Bobcat698's Avatar
The last set I put on, we cut through most of the crossmember.
Its hard to put the saddle clamps in though unless you can straddle it.. Otherwise you end up drilling a hole that you can only reach if you cut a large one through the bottom of the crossmember to tighten the nut.
My stacks are behind the crossmember, but when I get my new box put in I will be cutting the crossmember to place them closer to the cab.
Old Nov 19, 2006 | 06:17 PM
CSAGrey1's Avatar
I didn't cut through mine. I used a 45* to help set the pipes forward towards the cab. I'm sure cutting it probably doesn't hurt much but I just couldn't bring myself to do it.
Old Nov 20, 2006 | 04:26 PM
Southern Pride's Avatar
i put mine behind the crossmember towards the bed, because im going to put a headache rack, and didnt want them too close to the rack due to the type that i want. being that i did it myself, i used some pipe that is cheaper quality, and i guess i got probably 2 or 3 more years left on it, and ill relace it with some square tubing for the piece that lays in the bed, like most of the logging trucks do back home..........
mkeanglorldo56
Nov 4, 2007 12:34 PM
nfsommer
21
Apr 4, 2007 03:45 PM
rockittboy
Feb 3, 2006 12:38 AM
GO 4LO
Sep 2, 2004 02:04 PM
PistolWhipt
32
Feb 19, 2003 04:40 PM
