Stacks???
Old Jun 20, 2006 | 12:02 AM
G-NOTE's Avatar
Question Stacks???
Does anybody know if the only way to split the stacks is after you have gone through the bed, or is there another way under the bed or up front???
I bought a toolbox that bolts down and leaves about 8-10 inches on either side of the box (perfect for stacks) but if I have to move it forward 8-10 than it will look stupid...
Old Jun 20, 2006 | 12:09 AM
TNutcher's Avatar
You might be able to do the trick with the 5x7 (or whatever size) metal rectangular tubing under the bed but not sure if it will be as wide as you want due to the frame rails... you could get a splitter pipe and run 2 seperate 90's up through the bed where you want the stacks possibly having to go around the frame rails though, post some pics if you can when you get it! I wanna stack mine w/a toolbox too haha. Good Luck!
TNutcher
nfsommer
21
Apr 4, 2007 03:45 PM
rockittboy
Feb 3, 2006 12:38 AM
Dodgezilla
Mar 20, 2003 07:49 PM
PistolWhipt
32
Feb 19, 2003 04:40 PM
35
Nov 8, 2002 08:36 AM
