Stacking TST and Edge Comp
Old Jun 2, 2008 | 11:38 AM
Redliner's Avatar
What Are The Downfalls Of Stacking The Two And Taping Pump With Both Of Them?????
Old Jun 2, 2008 | 01:22 PM
Mike D's Avatar
Do you know what a tapped pump wire does?
Old Jun 2, 2008 | 01:39 PM
AggieJustin's Avatar
You cannot tap the pump wire with both boxes. Only one of them can be used to tap.
Even if you did tap both and not blow up electronics, you're not going to get any additional fuel by sending two signals instead of one.
If you use both, the TST will be tapped to the pump and the Edge Comp would have to be run in EZ mode for timing and off-boost fueling.
ncruhl
Oct 6, 2009 10:05 PM
rockjeep73
Mar 25, 2005 03:34 AM
Zino
Dec 16, 2003 05:19 PM
mcevins
Aug 30, 2003 11:09 PM
hellotbone
Jul 12, 2003 12:58 AM
