Stacking TS MVP and Edge comp
just re-read and see you mentioned your 02. just read your sig and only saw 04
anyway - in order to run both of those you need to remove the timing from edge if you can.
instead of the edge and TS , go with the TS and TSTPM3. the PM3 is fuel only, so no timing issues. can also throw a smarty into the mix on fuel only - or with mild timing if you keep the TS turned down . . . a ton of options with that stack. i am running it right now and love it. very clean if i want it to be, but builds boost quickly when wanted.
lvmknsmoke..
Jan 17, 2025 09:14 AM
13jy831
Feb 25, 2011 07:45 AM
mx684
13
Jul 24, 2007 07:52 PM
JD farmboy
May 21, 2006 01:04 PM
rockjeep73
Mar 25, 2005 03:34 AM
