SS62 on 24V
Loosen up the bolts on the back of the compressor housing & turn the housing until it clears. This is called clocking the housing & must be done to align the oil tube also. Then retorque the bolts when finished.
Do you tow? If you do....a set of II 3 flows are a perfect match for the SS62. No egt worries & everything works perfect from spoolup to peak. I run the 4 flows & have no problem, but the turbo does like to be above 2000rpm to stay happy.
I was planning on mach 2's and an drag comp smarty stack....
Whacha thank?
I have an ez w/ the map unhooked, and a FASS. It actually spools pretty good right now
SOme more down low fueling im sure it will rock...
Whacha thank?
,.........unless you tow heavy then the adjustability of a box is nice
I'd like to add that I did get a chance to do a little towing with the 4's and my 64 (which I'm told flows less air than the super 62's). Towing an acura around the flatlands of va and all I saw was 900
The mach 2's will work well with the smarty/comp, but I would check out the new quadzilla race box....should be released soon. I am running the "70hp tow box" & it definately is a improvement over Smarty for a tow rig. It is also adjustable on the fly. The race box will have no limit to low end fueling & will be rated around 180hp. Well worth the wait.
you should have the map plugged in to do the boost fooling so it does not defuel over 20psi, I have been towing with 120's and a van aaken, pretty much the same as the ez and it works great, the smarty fuels to hard on the bottom to tow with for me, I worry about breaking the trans
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
J Lent
Jul 31, 2007 07:09 AM
dodgediesel
Apr 15, 2007 11:33 PM
.. and i finally got it... Its all on. And runnin good. I need some more fuel now
