Spool up HX55
Old Mar 8, 2008 | 09:45 PM
Big Blue24's Avatar
Spool up HX55
Why do the HX55's spool slow when they have roughly the same size wheels as an HTT 64/71 ??
Is it that you cannot get a small enough exhaust housing? Is the shaft a lot bigger? Are the wheels just heavier? What makes the S300 based 64/71/14 so much faster to spool than HX55?
http://cgi.ebay.com/ebaymotors/HUGE-...spagenameZWDVW
According to this ebay listing, this turbo has 65 mm compressor bore so 64mm compressor and 72mm exhaust turbine wheel bore so 71 mm turbine.
Old Mar 9, 2008 | 09:33 AM
Ph4tty's Avatar
Its the housings. Rowland ran a 55 with a small housing with good results before, while just about everybody else I've talked too had bigger housings and couldn't spool it well. I see some 19's in the casting of that holset, so may thats a 19 cm? JR Adkins was the one pushing the custom 55's and the price of the smaller housing was pretty high.
Old Mar 9, 2008 | 09:42 AM
dieselrob's Avatar
The exhuast housings are usually big unless some one worked it over.
Old Mar 9, 2008 | 09:47 AM
Ph4tty's Avatar
And to correct myself, those 55's I was referring to were "baby 55's", some sort of hybrid.
Old Mar 9, 2008 | 10:32 AM
ILLINOISRAM's Avatar
I have one of the little 55's. It is actually a H2E/HX40 because i had to have it rebuilt. Since the rebuild it is now in about a hundred little pieces. Good street turbo but not good for pulling on a 12valve with a lot of fuel. It oversped the compressor and blew the many pieces of the wheel through the comp. housing and broke the cartridge in about 4 peices. So basically i have a good tubine housing left. The comp. nut is still on the shaft so that might be good too. LOL Tim
Old Mar 9, 2008 | 05:24 PM
Rods's Avatar
That turbo is just like a HX52 if not one , most 55s use the same inducer but the turbine is 77mm instead of 71or2 like the 52s are ... email them and ask what # is stamped inside of the turbine housing 52s are usally 16cm
Quiet Riot
13
Jan 27, 2008 04:59 PM
SjLingenfelter
Jul 29, 2004 04:14 PM
Forrest
43
May 19, 2004 08:47 PM
Hired Gun
Mar 20, 2003 10:04 PM
cliff-1972
0
Oct 13, 2002 04:04 PM
