Specs on an H2E?
Old Feb 11, 2007 | 01:21 AM
cumminsdriver635's Avatar
Specs on an H2E?
Anyone know the specs on a holset H2E? Im looking for compressor size, inducer size, exhaust housings available, etc. A boy i know is running one, but doesent know much about it. Just curious as to the size of it.
Eric
Old Feb 11, 2007 | 09:27 AM
mainer's Avatar
i've searched many times for info on them and could never find much
think they have a 17cm and a 19cm hot sides. they do have a different flange on them... requires spacer so you can bolt it up to stock manifold.
Old Feb 11, 2007 | 09:36 AM
signature600's Avatar
17 or 19cm turbine is the most common...they can be machined to fit other housings, but most aren't. Compressor sizes can be had up to about 71mm IIRC
Chris
Old Feb 11, 2007 | 01:39 PM
Hmm. Looks like its gonna be hard to figure out any real specifics on it then. It didnt seem to spool too bad on his truck. The exhaust outlet is 5 inches, but he has it necked back down into 3 . He was trying to tell me he could run the work stock class at scheid with it, because it "looks stock". I told him he was crazy. The only thing that looks stock to me is that it says holset on the compressor housing.
Eric
Old Feb 11, 2007 | 02:15 PM
PourinDiesel's Avatar
Dont waste your time with an H2E.
Old Feb 11, 2007 | 03:14 PM
Rods's Avatar
most have a 63mm compessor wheel , i got about 3 housings if needed 17cm one has a stock foot print other has a wastegate , there good up to 50lbs i wouldnt go over that or if that
Old Feb 14, 2007 | 02:21 AM
His seemed pretty stout with the H2E when it spooled. What do they come stock on anyways? i dont think his had any kind of adapter to the exhaust manifold. it was fairly laggy. I think it lit around 2200 or so in a 5 spd with a 0 plate, 370's, and laser cuts.
Eric
Old Feb 14, 2007 | 08:01 AM
Came stock on the old L10 engines.
Chris
Old Feb 14, 2007 | 11:04 AM
mainer's Avatar
there was a truck on ebay a few weeks back that had one..... i cant find the link now i think it was a 95 4x4 reg cab IIRC
Old Feb 14, 2007 | 10:55 PM
9812VCTD's Avatar
I've been kicking around the idea of throwing an H2E on my truck I've got one laying around with a 17 housing. I was going to put it on a powerstroke I had. cumminsdriver635 is there anyway that you could get a few pics of your friends setup? Would be nice if you could get a little smaller housing for them like a 14.
Justin
Old Mar 8, 2007 | 06:29 PM
Justin
Hey man, I got a better look at it today. It all bolts up just exactly like a factory turbo on his truck, except the 5 inch exhaust outlet which he has rigged into his exhaust. he said he has a housing for it that is made for a 4 inch exhaust. it came with the turbo when he bought it. He said he was gonna sell it. He'd like to get $400 out of it. Id almost buy it, but I dont need it. Im sure it would spool pretty slow on my truck.
Eric
cummin2tkme
Dec 31, 2003 08:50 PM
Hawkeye
Sep 23, 2003 08:22 PM
cummins24
Apr 13, 2003 10:06 AM
C4L
Feb 13, 2003 03:43 PM
