Speakers
Speakers
What size are our speakers in our rams? (ie. door speakers ad the ones behind the seats in a single cab) And also if they are oblong speakers is there a round speaker that will fit the holes??<br><br>thanks <br>Ian
Re:Speakers
[quote author=Jamie Attridge link=board=7;threadid=14461;start=0#135833 date=1052324661]<br>Don't use 6x9 in the front make a bracket and put a component set in they sound way better.<br>[/quote]<br><br>I was thinking the same thing but how would i go about making a bracket?????
Re:Speakers
That's what I did with my setup. Minus the plywood (I'm doing that when I install the new Alpine ;D). The components are real nice. I mounted the tweeters in the top of the doors. If I had to do it over again, I'd mount them in the top of the pillar.
Re:Speakers
I put a set of Infinity Kappa 6x9 2 ways up front. These have large magnets. They came with faces for surface mount. I removed the wire screen flipped it over and used that as a spacer. The factory infinity setup was removed. I also unhooked the factory tweets.<br><br>For the rear I used Infinity reference 6.5 seperates. The tweets are mounted high on the door and are -3db.<br><br>All speakers are driven by a 4x50 amp. It sounds good no matter where you sit.<br><br>The factory deck is still used, for now.
Re:Speakers
Stakeman why would you mount tweeters in the rear? Im not sure on this the whole point is to have the highs singing up front. Pillar mounted tweets are the preference and also dash mounted the reflect off the glass. The point of a tweeter is to have the opposite side of the truck point at your ear so the right side of the truck will point the tweeter at the drivers right ear and vise versa for the passenger. I have always prefered a component set for tweaking the sound to my likeing the 6x9's you get are already capped at certin frequencies so its not easily tuned to sound as good as a set of components. I highly recommend the JL audio line for speakers along with the Focal line if you have the dough. I run the focals and they are state of the art and work amazingly. I have yet to see a set distort.
