south bend question
Old Jan 7, 2009 | 04:05 AM
Flatbed24v's Avatar
south bend question
I have been looking at their dd clutches and was wondering what the differance between rigid and sprung? I have been told that I should get the 3600 ( most likely the 12cb for the sled), but has anyone driven the 3850 or 4200? Can these be driven daily? Why or why not? I don't mind a heavy pedal.
Old Jan 7, 2009 | 03:08 PM
Flatbed24v's Avatar
does anyone that drives a south bend know what the diff between rigid or sprung? Or can help out with my other questions?
Old Jan 7, 2009 | 06:22 PM
dieselrob's Avatar
I think the srung hub is to kind of take some shock out of the drive line by giving a little on engagement. If you spend most of your time on street dont get the 3850 or up in my opinoin( do to my personal experiences). My buddys 06 just lost its 3850, daily driver, the fingers in the pressure plate twisted and toasted the whole clutch. Only 10k mile on it, but driven in to much stop and go traffic for that clutch. Best bet is call south bend and talk with peter and he will guide you to the right clutch.
Old Jan 7, 2009 | 06:52 PM
Tate's Avatar
Sprung hub has springs in the disc to dampen the vibrations from the engine to the drivetrain. The solid hub obviously lacks those springs, and will transfer vibrations. I daily drove a 3600# solid hub for two years, no complaints other than the slower shifting. It had a stiffer pedal to it, which I liked. My 12v has a 3250# sprung hub. Shifts faster and seems smoother. The 3250 has a diaphragm style pressure plate, while the 3600 is the older style that used the lever style pressure plate. I have heard the 3600's are available as a diaphragm now as well. Invest in a fluid damper with whatever one you go with.
Old Jan 7, 2009 | 07:22 PM
6WHEELER's Avatar
I drive a 3850 12puck on the street. I don't have any complaints with it. It's ether ingaged or it's not. The pedal is not all that much heavyer than the stock. got used to it in a week or two" i have got the hyd upgrade ". It shifts slower than the OFE I had. but I don't drag race, got it for pulling. I have got about 7000miles on mine. The sprung hub is quiter than the solid, less rattle from what i was told. I beleave it is suppose to shift easyer also. never had the solid
Old Jan 7, 2009 | 10:28 PM
Bluedually4x4's Avatar
Do you need a dd because of the power you want or are you going to sled pull? Just asking cause I have one of their single disc clutches and have yanked two mobile homes with it no problem.
Old Jan 7, 2009 | 11:38 PM
Flatbed24v's Avatar
bluedullay4x4, to anwser your question would be both. I plan on twins, Mach 4, and a smarty stack. I am also wanting to get into sled pulling a little
Old Jan 7, 2009 | 11:54 PM
J Lent's Avatar
Just be sure to get a SFI approved clutch. I would get a 3600 12cb, I had a 3250 & It didn't like the heat very much. Any more pressure & you will shorten the clutch life on a DD.
Old Jan 7, 2009 | 11:59 PM
Flatbed24v's Avatar
SFI approved?????
Old Jan 8, 2009 | 05:08 PM
mdavlee's Avatar
yes they are unless you get the ductile iron flywheel
Old Jan 8, 2009 | 05:35 PM
Flatbed24v's Avatar
what does SFI mean and mdavlee are you saying that all of the ones mentioned above are SFI approved unless I get a di flywheel?
Old Jan 9, 2009 | 09:38 PM
mdavlee's Avatar
Yes they are sfi unless its the ductile iron which is a lot cheaper than the others. sfifoundation.com will answer all the other questions. A 3600 is a lot easier to drive on the street, but I drove a 3850 for 20000 miles on the street in an 07. The 3850 is a little bit heavy for a daily driver but will hold up better sled pulling.
Old Jan 10, 2009 | 12:19 AM
1stGen72's Avatar
I have the SBC DD 3850 Street Comp 12 CB Rigid in my dually and i pull a 40 trailer with it and an every day driver and have no problems what so ever lover it. Also for sled pulling works AWSOME. It does rattle a little bit when the clutch is in but i think that is norm for a DD clutch
Old Jan 10, 2009 | 08:48 AM
mdavlee's Avatar
The sprung hub makes them a lot quieter the 3600 in my 97 doesn't rattle hardly any, but the 3850 that was in my 07 rattled a lot and you could hear it all the time the clutch was disengaged.
Old Jan 10, 2009 | 12:53 PM
Tate's Avatar
Both my 3250 sprung and 3600 unsprung make noise when the clutch is disengaged. They are about the same volume too. With the windows rolled up, you really don't hear it though.
crewcabxlt
Aug 29, 2009 08:57 PM
Jethro6213
Jan 26, 2009 12:54 AM
Snoxracer
Aug 11, 2008 06:07 PM
ddestruel
Feb 28, 2008 03:05 PM
Big Smoky
Mar 31, 2005 01:22 PM
