Someone has to....
Someone has to....
Someone has to make a billit output shaft for a 47RH....
I just broke mine today spoolin it up ,got to 20psi and boom she blew.
if nobody does then who can make them .
I tried every body , evan DTT and they all said you can't break them so we don't make them . yes evan DTT said they never oder any cause they cost to much to have made . So I have sent one to a candian company and there are going to spec it ,but they beliave we are lookin at 750.00 each for 10 of them . So if that is going to be the price I am going to have them made up I should be able to off that many.
it not that it is that hard to find a replacement , it is the inconvenice of the down time ,the cost of fixing it ,and my main problem the loss of the points at the event. as far as a fusible link if your worried ( the RE guys have full billit why not us ) use greaseable U joints they are weak enough to break and you can fix them at an event or home and it is a cheap fix. Each to there own thow. I just have a 7000.00 trans witch I perfer not to have or be my fuse.This probably is not a problem for a 600hp or less truck So depending on what you do with or want to do with your truck will depend on if you want or need to have billit parts.
Agreed, it all depends on how much boost you want to launch with.
I try to keep it around 10 psi and come out of the hole a few feet before stomping on it to keep from "blowing the Dodge Drivetrain Fuse".
But then I'm not looking for Warp Factor 9 time slips either.
http://www.gbtransmissions.com/ have u tried them ???
shoot let me use the 95 this year u have enough with the Dmax
If you come up here I'll let ya have ago with it , I'll try them again tomarrow ,I called allday today but there line is allways busy and I hate leaving messages. OH by the way my GT42R is kickin <edit>, I might go to a T80 Y2K how is you T doing???
Hey now ill come and get no ?s ask LOL we have a points pull down here and that truck is set perfect for it ..U can sponcer me this year
.... shoot man i sold the 70 little to big for daily
Great to here the GT is working good !!!!!! u know u can get 80mm wheels for that too
