Someone with a 4x4 help?
Old Feb 9, 2006 | 12:06 AM
ASTAR's Avatar
I need the measurement from the center of the hub (wheel) to the bottom of the fender. Right where the sheet metal starts please. Both Front and Rear.
Thanks
Old Feb 9, 2006 | 12:08 AM
BigBlue's Avatar
Do you care if the truck is lifted or not?
Old Feb 9, 2006 | 12:21 AM
ASTAR's Avatar
Sorry, I should have said, needs to be stock.
Old Feb 9, 2006 | 01:18 AM
BigBlue's Avatar
Ahh. Well that rules out my truck. Although I could just take off 4.5".
Old Feb 9, 2006 | 02:06 AM
ASTAR's Avatar
Hey thanks anyways. See the reason I need it is because I an doing some custom suspension to my rig and I need to know where it sits stock so i can compare it to what mine is now. That way I can take the actual numbers (not the word of a lift kit company) and make the adjustments I need. See, my ift is a 5.5 SkyJacker + 2" lift coil spacers but I need to be positive in what my actual lift number is for the front and the rear.
Old Feb 9, 2006 | 02:10 AM
BigBlue's Avatar
I can get ya some numbers tomorrow on a stock truck. When you get done building yours, will you build mine?
Old Feb 9, 2006 | 02:25 AM
ASTAR's Avatar
The numbers, I'd appreciate...building yours? Your a long ways away but I'll help you with it if you bring it over!
Old Feb 9, 2006 | 11:00 AM
Mike D's Avatar
24.5 front and 26.5 rear. Hope this helps.
Old Feb 9, 2006 | 11:30 AM
ASTAR's Avatar
Thanks a lot Mike
Old Feb 9, 2006 | 01:35 PM
BigBlue's Avatar
I got the same thing.
Old Feb 9, 2006 | 05:50 PM
graphitecumnz's Avatar
I get between 27.5" and 28" in the rear... I have camper special and trailer tow package though
24valver
Apr 14, 2009 01:09 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
omaharam
May 2, 2006 05:46 PM
