Snapping turbine shafts why?
Old Feb 12, 2009 | 10:14 PM
kgspeed700's Avatar
This is the second time this has happened i run a 64-68-14 s300 based turbo with all the other mods in my sig.. it was built by tim down in VA. any ideas would help thnks
Old Feb 12, 2009 | 10:26 PM
dieselcamp's Avatar
Better see if you have good oil flow to your turbo. If there has been a previous failure where metal is in the oil, the cooler may be plugged with debris.
Old Feb 12, 2009 | 10:35 PM
estrada5.9's Avatar
I snapped a shaft on a ht3b and i still don't know why it happened everything look good to go when i took it apart and put another one in. maybe oil drain gasket is not lined up or the old one is still on there and in the way.
Old Feb 13, 2009 | 11:34 AM
dstad's Avatar
when you shift or let off from high rpms are you barking the turbo because that will do it for sure.
Old Feb 14, 2009 | 11:30 AM
HOHN's Avatar
A larger housing in some cases can help shaft life by reducing transient stress.
Old Feb 14, 2009 | 03:34 PM
Wicked500R's Avatar
+1....message too short...lol
d22019
Sep 27, 2012 08:52 AM
sgrooms
21
Apr 8, 2008 11:17 AM
Burning Oil
Apr 12, 2007 06:48 PM
somis13
13
Sep 8, 2006 05:59 PM
Mexstan
25
Apr 30, 2003 04:26 PM
