Smoke
Old Dec 25, 2006 | 09:04 PM
Bigoledodge4x4's Avatar
Smoke
Is there anyway to get more smoke out of my truck,I have a 99 ext cab swb 4x4 auto with edge w/att sliancer ring taken out Stock intake and exhaust for now...I got a buddy with a 95 straight piped silancer ring out star wheel turned up and and i think he said a num 5 fuel plate is what he called it. and he justs smokes everyone out...anyway to get mine to do that????
Old Dec 25, 2006 | 09:07 PM
mysterync's Avatar
Yours is electronic, you can do that. You can buy a smarty or a set of sticks, but no easy screw turnin on these trucks, Sorry man! Then youll need a tranny, and intake, and probably a turbo, Make sure you have a good fuel system and some gauges
Old Dec 25, 2006 | 11:22 PM
kelownadiesel's Avatar
youve got a juice with attitude? Ive got a comp which is the same basically.If you tapped the wire you shoud have crazy smoke with all that stock stuff
Old Dec 26, 2006 | 07:51 AM
mysterync's Avatar
Not like a 12v with a plate slid up and the starwheel maxed out
Old Dec 26, 2006 | 02:16 PM
Dodge12vKing's Avatar
You speak the truth.
My dads 99' will not smoke at ALL. He has the Edge Comp and I don't think it's getting enough fuel or something, maybe he needs a lift pump.
Old Dec 26, 2006 | 07:02 PM
blackdiesel's Avatar
Registered
on a truck with a comp on it you can unplug the map sensor, and get tons of smoke. It will probley work on the juice as well
Old Dec 26, 2006 | 07:08 PM
mysterync's Avatar
I think i should try that! Whatcha think black?
Old Dec 26, 2006 | 07:11 PM
jta's Avatar
jta
I have the juice with a 4" exhaust and I can make mine smoke pretty good. It is enough that the tailgaters don't like it, and I have not even tapped the pump yet.
Old Dec 26, 2006 | 07:38 PM
I can dump smoke out of mine like you wouldnt believe.I have a smarty too though
Old Dec 26, 2006 | 08:46 PM
mysterync's Avatar
i think he's looking at it as compaired to a 12v. A 12v setup hard with a stock turbo will role a dense dark cloud! moreso than a 24v with just a comp
Old Dec 26, 2006 | 08:54 PM
scottsjeeprolet's Avatar
I know with a Comp you just have to unplugg the MAP at the block and you get smoke and lots of bottom end power. I'm not sure if it works with the juice, but go ahead and try it and let us know.
Old Dec 26, 2006 | 09:15 PM
natew05's Avatar
Now i also heard about unpluging the map to get tons of smoke. I tired that and i got no power and a check engine light. I put the tst power mx2 stacked with ez and it smokes decent. but the map thing didn't work at all for me
Old Dec 26, 2006 | 09:20 PM
Registered
it won't work with a tst
Old Dec 26, 2006 | 09:22 PM
mysterync's Avatar
has our little buddy in black been trying to smoke more !
So supprising..... thats the only way i can figure that you would know that it didnt work with tst!
I guess im kinda starting to feel these guys saying smoke will be the end of this hobby! that would suck, strict laws suck period!
Old Dec 26, 2006 | 09:30 PM
natew05's Avatar
interesting i didn't know it wouldn't work with the tst, why is that?
