Smoke
Old Dec 26, 2006 | 09:39 PM
bigredBCS's Avatar
can u unplug the map sensor on 3rd gens?
mysterync's Avatar
i dont think it works on third gen eaither ... too smart for that!
Old Dec 26, 2006 | 10:05 PM
scottsjeeprolet's Avatar
From what i understand if your box is a boost fooler, like EZ or Comp unplugging the map will work. As far as the other box's i don't know. But without a boost fooler you will get no power and a CEL.
Old Dec 26, 2006 | 10:15 PM
mysterync's Avatar
Right, It fakes the map signal if its a boost fooler, it says 0 boost if unplugged, if it dosent boost fool it gives the truck no signal
Old Dec 26, 2006 | 10:29 PM
blackdiesel's Avatar
Registered
no I didn't have to try it. I knew it wouldn't work when I switched from the comp. I have plenty (to much) of smoke before I spool the way it is. I don't see how you could tell the difference either.
Old Dec 26, 2006 | 10:55 PM
mysterync's Avatar
hahahaha! I think in gonna put a sps 66 on the duramax with injectors !
I was just giving ya heck black diesel
Old Dec 27, 2006 | 10:58 AM
ohiostate24's Avatar
So if you unplug the map sensor, your boost gauge will show no boost? Is that correct?
Old Dec 27, 2006 | 11:06 AM
12valve's Avatar
Originally Posted by Dodge12vKing
You speak the truth.
My dads 99' will not smoke at ALL. He has the Edge Comp and I don't think it's getting enough fuel or something, maybe he needs a lift pump.
YEah fisrt thing: hook up a fuel pressure gauge.
i put an edge comp on my 98 24v, a good time ago, and it didnt really smoke, a few weeks after, i realized the lift pump didnt even run (0 psi)
you should at least have 8 psi on 5x5 on a wot run
Old Dec 27, 2006 | 11:11 AM
Registered
NO your boost gauge is a manual gauge in the intake, and the map is ele. and if you unhook it it don't know the difference
Old Dec 31, 2006 | 01:02 AM
Bigoledodge4x4's Avatar
I did the wire tap and it only smokes alittle bit after im rolling about 40 and get on it but nothing much...also i have been blowing the aftercooler rubber boots off where it goes from the turbo down...whats the cause and the fix i'm boosting like 42psi at times when this happens.
Old Dec 31, 2006 | 08:25 AM
mysterync's Avatar
Are you running injectors? It could be a little bit of oil on one of the flanges. Put some info on your sig. We'll be able to help more. Didnt you say u were just running a edge juice with attitude? No turbo? If your on a stock turbo your just building heat and loosing power at 42 lbs. Most all the big turbos are starting to run out of efficency right there. I run 45 50 on mine. I went to a HTS Boot, They work really well and stay on , but if you think your just running 42lb with a drag comp wire tapped there something fishy
Old Dec 31, 2006 | 08:33 AM
Registered
Originally Posted by mysterync
I think i should try that! Whatcha think black?
pull it and get a video!
Old Dec 31, 2006 | 08:44 AM
mysterync's Avatar
Aight, I can do that Olee Poole will Probably kick my *** But hey,!
I might try that for poops and giggles
Old Dec 31, 2006 | 08:53 AM
RustyJC's Avatar
I guess im kinda starting to feel these guys saying smoke will be the end of this hobby! that would suck, strict laws suck period!
Here's what we already face in Texas regarding smoke:
Smoking Vehicle Report
Now, if certain individuals keep smoking out the soccer moms in their minivans, it's only going to get worse!
Rusty
Old Dec 31, 2006 | 09:07 AM
Registered
Tailpipe smoke is a result of incomplete fuel combustion, which is usually caused from improper engine operation in both gasoline- and diesel-powered vehicles. When a vehicle and its engine are not properly maintained, the likelihood of engine problems and smoke increases.
it says that we'll also recieve a paper on how to "properly maintain our vehicle"
