Smarty stack with ez
Old Jan 19, 2010 | 09:04 PM
kyle_truck_pull's Avatar
On the vp trucks can u stack the smarty programer with an ez box? Will it work ok?
Old Jan 19, 2010 | 09:57 PM
pokapotato's Avatar
Sure. Just use the tunes that do not add timing.
Old Jan 19, 2010 | 10:58 PM
DodgenIt's Avatar
That would be a pretty good stack. X2, keep off of the timing levels on the Smarty and all will be good.
Old Jan 20, 2010 | 08:35 PM
rage_blue's Avatar
I ran the Smarty stacked with the EZ, ran timming on the smarty, seamed to work just not on 9, had to run on 7. Couldn't pull a load on 7 but 8 worked okay if it was a light load, anything heavy i backed it down to 3 i think it was. HAd that turbo blow up last fall and the injectors craped out so now i'm **** near stock,
Old Jan 21, 2010 | 07:27 AM
johnyb59's Avatar
Run the Smarty on even levels and you'll be just fine
Topper
Mar 3, 2008 10:17 AM
white250005
Oct 25, 2007 10:19 PM
smoky beast
Oct 18, 2006 06:58 AM
B.Law
16
Apr 22, 2005 02:28 PM
Cat Cracker
Jul 14, 2003 12:17 PM
