Smarty S03 - Returning to stock question
Old Jul 1, 2010 | 09:06 AM
Mechanos's Avatar
I was reading through the FAQ page on Mads Electronics web site and came across this:
Q. Which version of "stock" will the Smarty come with.
A. Smarty does NOT download the complete original software from the ECM and does not store it into it's memory. That
is for a simple reason. The protocol in the ECM does not allow to read the flash memory.
How can Smarty then return to stock? Simple he has all the latest stock softwares already on board. When you choose
to return the truck back to stock, Smarty takes the stock software from it's memory and updates the ECM with that
software.
Which raised a question... I put a different sized tires on my truck several years ago and had the computer re-flashed a the dealer with the new Revs/mile number so my speedo/odo would read correctly and the auto trans would shift at the right time, etc. If I use a Smarty to reprogram with one of the performance softwares and then later use the Smarty to go back to stock, will it overwrite my previous revs/mile flash with the "stock software from it's memory" and remove my previous revs/mile flash?
If that's the case, then I could never really remove the Smarty and return to where I was before using it without having to pay a dealer to re-flash the correct revs/mile value.
Old Jul 1, 2010 | 09:17 AM
Homestead's Avatar
This seems to vary among Smarty users.
When going back to stock programming, some trucks lose the tire size and others keep the tire size.
On my particular truck, when I go back to stock, the tire size stays as it was programmed and my speedo stays accurate. I know more trucks that stay accurate than those that lose the tire size.
I wouldn't worry about it because chances are you will always run a Smarty level of some kind anyways. It sucks when you go back to stock for any length of time.
Jeff
Old Jul 1, 2010 | 09:29 AM
Mechanos's Avatar
Out of curiousity.... how did you verify that your truck did not loose the tire size?
Old Jul 1, 2010 | 01:21 PM
Homestead's Avatar
When I set my tire size, I do it using the GPS mounted on my dash until both the speedo and the GPS read the same. When I go to stock, the speedo continues to read the same as the GPS.
And yes, GPS can be off when it comes to speed and distance but mine has been "tweeked" by someone I know in the military and all the "errors" in this civilian GPS unit have been removed. They say that civilian units can't be adjusted, they can.
Jeff
dg164
Oct 24, 2013 03:55 PM
blue2002
Aug 26, 2013 10:14 PM
blue2002
0
Sep 20, 2011 08:16 AM
bluebull
14
Nov 30, 2007 02:28 PM
