For the SMARTY guys
Old Dec 16, 2006 | 09:58 AM
Shovelhead's Avatar
Administrator / Scooter Bum
For the SMARTY guys
I tried a SMARTY last year at Claremont and I am told the fast idle-three cylinder cold idle is left behind after the smarty is removed and programing was returned to stock.
What steps are required for it to engage?
At what temperature?
Old Dec 16, 2006 | 10:18 AM
mysterync's Avatar
Under 32 i belive parking break on, not using clutch throttle or break! Let the grids cycle first then crank and idle for about 10!
Old Dec 16, 2006 | 10:27 AM
Shovelhead's Avatar
Thanks.
Old Dec 16, 2006 | 11:35 AM
Ram1999's Avatar
Copied and Pasted from another thread:
Once enabled, idle speed will slowly ramp up from 800 rpm to 1200 rpm when all of the following conditions are met:
1. Intake Manifold Temperature less than 0°C (32°F) and,
2. Coolant Temp is less than 60°C (140°F) and,
3. The Transmission is in Neutral or Park and,
4. The Service Brake pedal is not depressed and,
5. Throttle = 0% and,
6. Vehicle Speed = 0 mph
Additionally, if Intake Manifold Temperature (IMT) is less than -9°C (15°F), and all of the parameters above are met, three of the cylinders will be shut off upon reaching 1200 rpm, creating a slight change in engine sound which is normal. This allows the engine to create increased heat in the cooling system, allowing more rapid engine warm up and cab heating.
Both features will automatically disable when one of the following occurs:
1. The Automatic Transmission is placed in gear (forward or reverse) or,
2. The Service Brake pedal is depressed or,
3. Throttle position is greater than 0% or,
4. Vehicle Speed is greater than 0 mph or,
5. Coolant Temperature is greater than 79°C (175°F).
Engine speed will return to normal operation at 800 rpm. If the engine continues to idle and coolant temperature is at or below 60°C (140°'F), the feature will reenable. In order to operate properly, the Accelerator Pedal Position Sensor (APPS) must stay at idle.
Old Dec 16, 2006 | 11:43 AM
Shovelhead's Avatar
I had read that before, but try as i might,....I couldn't locate that info.
Just printed it out so I can (hopefully) find it easier next time.
Thanks.
stock03
34
Apr 21, 2011 07:40 AM
UnrulyNFS
Feb 21, 2007 08:21 AM
04ctd
Sep 10, 2006 02:58 AM
bnold
39
Jun 4, 2006 08:21 AM
bentwings
Jul 9, 2004 02:23 PM
