Smarty???
Old Oct 4, 2007 | 04:32 PM
JIT's Avatar
JIT
Smarty???
Would a SMARTY do me any good stacking with the Edge? If so where would it supply the extra power? Thanks in advance.
Old Oct 4, 2007 | 04:55 PM
blackdiesel's Avatar
Registered
IMO. it wouldn"t be $$$ well spent. Get a bigger charger, if you want to spend some money. JMO
Old Oct 4, 2007 | 07:03 PM
JIT's Avatar
JIT
thats what I figured! I bought the HX35 and down pipe I have now from you and it has been great! Thanks again. Looks like its time to step it up one more time!!!
Old Oct 4, 2007 | 07:07 PM
srt20's Avatar
I got a Smarty/Juice/sticks. Its a very nice combo, but way to much for any kinda playin with the HX35.
Old Oct 4, 2007 | 07:08 PM
Scott07's Avatar
Smarty stacked with an Edge would not work out very good. You can only use the no timing added settings on the Smarty, which will defeat what the Smarty is great at to begin with.
Stacking the Smarty with a fueling box would be the way to go...TST Powermax3, Quadzilla Xzillaraider, etc. Seems like TST PM3 and Smarty is the stack to have with the 2nd gens.
Old Oct 4, 2007 | 07:14 PM
Aosipower's Avatar
Scott07, not arguing, but have you ever ran a smarty with an edge? I would not be without my smarty/edge stack and I have heard, no personal experience, that the tst/smarty stack will shudder the pump on the upper settings. I have also heard numerous people who have run both stacks say they prefer the comp/smarty stack for over all driveabiltiy and smooth power.
Old Oct 4, 2007 | 08:05 PM
Scott07's Avatar
Yes, I have driven trucks with the Edge/Smarty stack along with the TST/Smarty stack.
I hear mixed things though...
Some like the Edge/Smarty and some like the TST/Smarty stack.
Currently I am debating between stacking mine with the Edge Drag Comp or TST Power Max3....
Old Oct 4, 2007 | 08:10 PM
jazz_kt's Avatar
I have both with the smarty and prefer the drag comp over the pm3.
Old Oct 4, 2007 | 08:11 PM
Aosipower's Avatar
Nice, I was just wondering if you were drawing from personal experience or just research, yea both setups have their advocates...
Old Oct 5, 2007 | 08:36 AM
BarryG's Avatar
I have the smarty and juice with rv275s. It runs pretty darn well and no problems. If I didnt have the edge I probably would go with a tst so I could take advantage of the smarty timing but I cant complain about the setup I have at all.
Old Oct 5, 2007 | 09:11 AM
Scott07's Avatar
A few of my buddies around here are running the Smarty stacked with a Drag comp, running timing on both...seem to be running real good. 40lbs of boost with Smarty and 150hp injectors, and around 60lbs of boost with the Smarty, injectors, and drag comp on...this is on a stock turbo as well...
Old Oct 5, 2007 | 09:14 AM
JIT's Avatar
JIT
60lbs of boost on a stock turbo?????????
Old Oct 5, 2007 | 09:19 AM
Scott07's Avatar
Yes, unless his boost gauge is lying.
I have no idea how anything is holding up...stock turbo and I believe head gasket and studs...
Old Oct 9, 2007 | 06:08 PM
rip 112's Avatar
I feel sorry for that turbo...
stock03
34
Apr 21, 2011 07:40 AM
RyeThomas
40
Apr 20, 2007 10:12 PM
BigBlue
Nov 22, 2006 02:46 PM
bnold
39
Jun 4, 2006 08:21 AM
CTD_Neil
Feb 23, 2006 09:27 PM
