Setting the wastegate
Old Mar 15, 2008 | 11:16 AM
Pike's Avatar
Can a wastegate be adjusted on a 1998.5 24v motor? I didn't think it could be. If so, how do I do it? I want to set mine to 35 psi. Thanks
Old Mar 15, 2008 | 11:44 AM
Copenhagenjunkie's Avatar
I used a turbo master to adjust mine. I see no real gains after 32 psi except heat so that's where mine is set.
Old Mar 16, 2008 | 10:59 AM
Pike's Avatar
What's a turbo master?
Old Mar 16, 2008 | 11:15 AM
Here is some info about it but I don't know if they are being made any more.
http://www.dieselram.com/reviews/turbomaster.htm
Old Mar 16, 2008 | 11:27 AM
logskidder's Avatar
You can adjust the boost within reason....for more boost make the rod shorter and for less boost make it longer. You can use a boost elbow, however its more of a delay than a overall adjustment.
Old Mar 16, 2008 | 12:04 PM
Pike's Avatar
Thanks guys-I thought it could be done by changing the length of the rod, but wasn't sure. My truck doesn't have a boost elbow, but it will peg the 35 lb gauge with at least 40+ lbs, and has blown intercooler boots off towing. I want to limit it to 35 so I won't have to worry about it.
Old Mar 16, 2008 | 12:16 PM
Big Blue24's Avatar
Pike, this is what you need, set screw tight for maximum boost, loosen it to limit boost. Pretty simple, no need to remove turbo or mess with anything else. If you are hitting 40 already, you probably have disconnected the hose or vice gripped it shut.
FYI in stock condition, your wastegate should limit boost to 20-21 psi.
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
Old Mar 16, 2008 | 02:56 PM
Pike's Avatar
Right now, my boost gauge is plumbed with fittings into that elbow off the turbo, but it is a good chance for leaks. I'm going to get that adjustable boost elbow off ebay, and then get a boost bolt to run the gauge to. Thanks a lot guys.
TxDiesel007
Nov 19, 2007 12:26 PM
HOHN
27
Aug 26, 2007 07:21 AM
Ace
Aug 13, 2007 08:47 PM
aggiehorsepower
Nov 19, 2006 11:42 PM
MoparRiggan
Oct 13, 2005 11:54 AM
