Setting Lift Pump Pressure
Just installed a Raptor 100 yesterday. It came with the fuel pressure set at 14psi @ idle and 9psi @ full throttle (driving down the highway). My truck is stock and I am wondering if I should turn up the pressure a bit or just leave it be. My gauge is reading pressure from a tapped banjo bolt on the inlet to the VP 44. Thanks.
I believe a lot of it too is on aftermarket pumps the pump starts running when you turn the key on. OEM starts the pump when the starter kicks in so you don't get all that head pressure. FWIW....
Swamp_Donkey
09-02-2009 11:05 PM
1985cucv
06-19-2009 06:35 PM
