scotty air question
Old Jan 7, 2003 | 06:11 PM
ox's Avatar
ox
scotty air question
how hard is it to cut that 4.5 hole in the truck and what do i use to cut it with can i use a plasma cutter and dose it make that much difference
Old Jan 7, 2003 | 07:13 PM
Got Smoke?'s Avatar
Re:scotty air question
[quote author=ox link=board=7;threadid=9345;start=0#89557 date=1041984703]<br> can i use a plasma cutter and dose it make that much difference<br>[/quote]<br><br> Plasma Cutter!?!? Get you a holesaw from your local hardware store!
Old Jan 7, 2003 | 07:14 PM
Don M's Avatar
DTR Advertiser
A normal bi-metal hole saw will cut the hole and arbor will cut the hole with ease...I would not use a plasma cutter because of the painted surface your working on.<br><br>The hole will make a difference in intake charge temps and lower EGTs more...I dont have empirical numbers though<br><br>Don~
Old Jan 7, 2003 | 08:00 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=ox link=board=7;threadid=9345;start=0#89557 date=1041984703]<br>how hard is it to cut that 4.5 hole in the truck and what do i use to cut it with can i use a plasma cutter and dose it make that much difference<br>[/quote]<br><br>As others have suggested, I'd stick with the hole saw ;D<br><br>As for numbers, it will depend on how heavily modified your truck is. On a stock or lightly modified truck (EZ, 275s) the cowl hole doesn't make a huge difference. Maybe about 50F difference at WOT between Hush and dual inlet mode. As you increase HP, the gap begins to widen to the point where we've seen an _extra_ 200F reduction (above the 200F reduction in Hush mode) at WOT with the dual inlets.<br><br>Rod
Old Jan 7, 2003 | 08:18 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
[quote author=Push Rod saw ;D<br><br> As you increase HP, the gap begins to widen to the point where we've seen an _extra_ 200F reduction (above the 200F reduction in Hush mode) at WOT with the dual inlets.<br><br>Rod<br>
<br><br>200F <br><br>That could literally mean the life of your Cummins!<br><br>Don't tell Scotty, his head is big enough already!
Old Jan 7, 2003 | 08:55 PM
Got Smoke?'s Avatar
[quote author=SFtopSGT link=board=7;threadid=9345;start=0#89612 date=1041992337]<br>
[/quote]<br><br>Somebody shoulda told Greg (Cummnzpwr) that about 2 &amp; 1/2 months ago!
Old Jan 7, 2003 | 10:34 PM
Lil Dog's Avatar
I think the plasma cutter would work great for that hole if you have one.<br><br>Hey it only sounds harsh, but the plasma cutter would do a better job on the metal with all the folds in the panel. If you are a good hand with the plasma cutter, go for it IMHO...<br><br><br>J-eh
herb
Jul 18, 2008 08:25 AM
nfsommer
Apr 16, 2007 09:21 PM
hellotbone
Dec 9, 2003 12:32 PM
CTDCAL
Mar 31, 2003 01:43 AM
Mopar_Mudder
30
Feb 17, 2003 04:18 PM
