RV 275 injector problems?
Guest
Posts: n/a
I'm looking at some RV 275 injectors for the future, and wondering if anybody has had problems with these, or any other performance injector. I've heard stories of tips sometimes breaking off, taking out pistons. I'd like to hear mileages you've got on them, how long you've had them in, etc., etc. Also, is there a way of telling when injectors are in need of replacing? I've got about 300,000k on the originals and all seem good, but how to tell for sure?
Re:RV 275 injector problems?
I've got 275's, and find them trouble free. I like the performance (slight increase, w/o smoke except under rare conditions). <br><br>I believe the breaking tips rumor comes from other, higher-performance injectors that have been highly modified with bigger or more holes in the tip. The 275's are a stock item and well within manufacter's limits. The only problems I've heard of is if you have problems with the install and don't get a fitting tight or a gasket seated. This could happen replacing your stock injectors regardless of whether or not you put in 275's.<br><br>You probably don't need injectors or you would know it in reduced performance. But when you do get ready, treat yourself to an upgrade.
ScreaminEagle
25
Nov 5, 2007 08:15 AM
flinn101
Feb 8, 2006 12:16 PM
