running a comp as an ez question
Old Jun 30, 2003 | 02:28 PM
bullfrogjim's Avatar
I have installed a comp box minus the pump wire for now and have a couple of questions. First, what exactly did I accomplish by installing the boost elbow that came with it? Also what kind of adjustability do I have without the pump wire hooked up or is all the adjustability strickly for fueling purposes.<br>Thanks in advance
Old Jun 30, 2003 | 03:16 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:running a comp as an ez question
This info is from www.edgeproductsinc.com forums.
Power Level 1 on the Comp is the same as the EZ, on Power Levels 2-5 addition power is added via the wire tap onto the VP44 injection pump. If the pump wire is not attached with a Comp Levels 2-5 can be ran, but the power gain is not any higher than Level 1, the power will come in much earlier in the throttle but overall gain is the same.
Old Jun 30, 2003 | 04:35 PM
BigBlue's Avatar
What he said. I run mine on level 2 mostly. Only time I put it on 5 is to show off at a stop light or something. ;D
Old Jul 2, 2003 | 06:32 PM
doug's Avatar
I run my comp w/o the pump wire too. What's cool is that you can map the low boost fueling levels to the primary power levels (1/1, 3/3, etc.) and then without the pump wire connected you have, voila, instant in-cab low boost fueling control. Mine gets level 3 most of the time but sometimes if I want to send a little smoke out the tail I'll move it up to 5 and let 'er rip.
taken5875
Apr 4, 2008 12:48 AM
rockjeep73
Mar 25, 2005 03:34 AM
hellotbone
18
May 16, 2003 04:40 PM
Jack Thorpe
May 8, 2003 04:25 PM
danlit
Feb 13, 2003 10:53 AM
