Re-torqueing and valve adjust....
Old Apr 27, 2006 | 12:16 PM
DieselJoe's Avatar
Just wondering a couple things here....how many times do you guys re-torque your studs after a new headgasket job with an new o-ring'd head? Also, obviously it is good to re-adjust the valve lash after a retorque but do you check them again after running for quite a while?
I have done about 3 re-torques on my head since installed with the new .010" over marine gasket and Piers o-ring'd head and am just wondering how many more times if at all I should get in there and do another re-torque? I do hammer on the thing about once a day during my daily drives to and from work when it warms up but I have heard after a good 2 to 3 re-torques from the initial install that you should be good to go for a while and only have to re-torque again after a weekend of really beating on it the drag strip for say or even a sled pull event. Just looking for experienced advice.
On the valve adjust, should I check the lash after a good amount of running say 10-20K miles as the new gasket settles in, kind of like one would with a stock truck doing it every 25-30K? No re-torque involved since I have done 3 already, just a lash check to see where they are at after some good miles of driving??
Thanks, Joe
Old Apr 27, 2006 | 01:35 PM
Crimedog's Avatar
I say the way to go for retouquing is the initial torque upon installation, one heat cycle, retorque again, retorque again after a couple of months. Adjust the lash everytime you retorque. Piers told me that people are retorquing every few months with head bolts and o rings, but the studs should be good once the gasket is seated. Valve lash should follow in the normal maintenence intervals after this.
Old Apr 27, 2006 | 05:06 PM
DieselJoe's Avatar
Thanks Crimedog, that was what I was thinking as well. Lash should still be done some where between 20-30K miles and I guess I could re-torque my studs here in another month or so to see if they tighten down any further or end up right on the scribe marks.
Joe
jaypry
Jun 29, 2014 12:29 PM
Vintage Empire
Feb 11, 2008 07:32 PM
Jeremy Cusick
May 20, 2004 05:50 PM
towin1JT
Aug 6, 2003 09:09 AM
