raising boost pressure
Originally posted by apwatson50
More boost isn't necissarilly what you want. If your pouring out the smoke at 35psi of boost you need more volume. If you can increase your boost efficiently then you get more volume, or you can get a bigger turbo that can move a greater amount of air at the same psi. Either way your going to need a bigger turbo to get enough air to burn the amount of fuel your injecting.
similiar in a sense is a how a torque wrench gives a good indication of bolt stretch which is what you are really after, not the torque number.
An Air Intake temperature gauge would help you tune it. Try to find the spot where the air temp goes way up with higher boost and keep it there. At least that's how I understand it. If you go past that point you're just defeating the purpose of getting more boost.
SylvanLaker
May 9, 2006 02:42 PM
dma251
Sep 21, 2003 06:22 AM
