quite possibly the best modification I've made yet!!
Old Sep 9, 2005 | 03:49 PM
  #46
suzukiZrider's Avatar
http://store.summitracing.com/defaul...h.asp&N=400330
theres the thing on summit
Old Sep 10, 2005 | 11:10 AM
  #47
lsgibb's Avatar
Fleetguard crankcase Vent system
I don't know if you've all seen this one yet but it is an awesome idea from Fleetguard and would take care of that **** blowby bottle all together. The only problem is the cost $240 from Cummins Intermountain. How difficult would it be to make up your own?
Fleetguard Crankcase Ventilation System
Old Sep 10, 2005 | 11:48 AM
  #48
dspencer's Avatar
Hmmmm, I think the Ford guys have the answer to the problem. Just route your hose into this:http://image24.webshots.com/25/2/63/...8mlLZCD_fs.jpg
Old Sep 10, 2005 | 11:57 AM
  #49
infidel's Avatar
So now the Ford guys can now argue over which brand of disposable diaper to use like we argue over oil brands.
Old Sep 10, 2005 | 12:14 PM
  #50
TORQUE's Avatar
LMAO , but you also need one to catch all the diesel leaking into the engine oil from the bad injectors,maybe a 45 gal drum in p/u box, or filter it and just plumb it back to fuel tank, for an endless supply.
Old Apr 23, 2006 | 01:42 AM
  #51
high country's Avatar
bringing it back for the new guys
Old Apr 23, 2006 | 09:27 AM
  #52
SmokeyBear's Avatar
anything new on infidels link?
Old Apr 23, 2006 | 10:49 AM
  #53
infidel's Avatar
Their website http://www.condensatorsales.com/ says that diesel units are sold out.
Doesn't matter though as you can make your own Condensator with a large fuel filter and housing from Napa, costs about $35.
I haven't put one on my own trucks but a friend has, says that no oily gunk is getting in the air box. Simple setup, the blowby tube connects to the filter inlet and the filter outlet connects to a hole drilled in the stock airbox.
My concern would be the bad effects if the filter should clog up on you. My friend has been changing his $12 filter every 3000 miles and hasn't had any trouble.
Old Apr 23, 2006 | 04:07 PM
  #54
Pooter's Avatar
Well, its not hooked up the same way any longer, but neither is the old exhaust(stacks now)
<-New owner...
Maybe Forrest has some insight on it though...
Old Apr 28, 2006 | 10:02 AM
  #55
Abbynormal's Avatar
Fleetgard Crankcase vent kit
The kit in this link is for 98-2002 24v models. Do they also have a similar kit for the 94-98 12 valves ?
Old Apr 28, 2006 | 10:39 AM
  #56
Abbynormal's Avatar
Well I did a little searching on Fleetguards site and seemed to answer my own question. It seems they do have kit for the older engines but their site is not the most user friendly. Whats a good Fleetguard distributor site that is a little more user friendly ?
Old Apr 28, 2006 | 11:06 AM
  #57
Eskimo's Avatar
The results from the testing lab (SRI I believe it was?) are done by the way. The device is a great crankcase vent, but adds 0 MPG and 0 HP. Great for the environment, but not for anything else.
Old Apr 28, 2006 | 11:27 AM
  #58
Abbynormal's Avatar
Bump
Originally Posted by suzukiZrider
If you used the kit off Summit, (top of page 2 on above link) does it evacuate to the exhaust ? If you just hooked up the vents to say #2 and #4 valve covers would this cause uneven vacuum, would you really need one on each valve cover ? Are there any performance/mpg gains to be found with this type setup ?
Anybody tried this ? I sure hate all the "undercoating" I have !
Old May 25, 2006 | 10:16 PM
  #59
Abbynormal's Avatar
Bump!
Originally Posted by Abbynormal
If you used the kit off Summit, (top of page 2 on above link) does it evacuate to the exhaust ? If you just hooked up the vents to say #2 and #5 valve covers would this cause uneven vacuum, would you really need one on each valve cover ? Are there any performance/mpg gains to be found with this type setup ?
So anybody think it would be odd to hookup the vents to the 2nd and 5th valve covers and weld the nipples to the downpipe ?
Old Mar 30, 2008 | 10:14 PM
  #60
TexMexCowboy's Avatar
Intristing. I am going to try this.
