questions about my 315's
Old Oct 2, 2003 | 10:28 PM
LE's Avatar
LE
Re:questions about my 315's
It depends on what 315s you chose to go with. All tires are not the same in terms of height and width. A 315 can be as tall as 35", or as short as 33.5. The most accurate way to determine speed is to use a GPS unit. Your trans will also shift a bit different due to the speed differential from your old tires to the new ones. LE
Old Oct 3, 2003 | 05:44 AM
jfpointer's Avatar
This little calculator will let you compare the two tire sizes and the associated errors in speed and odometer readings, plus give your new effective rear end ratio:
http://www.dakota-truck.net/TIRECALC/tirecalc.html
And LE is right, they're all potentially a little bit different, but this should get you pretty close. And yes, it probably will throw off the shift points a bit, since the speed signal will be wrong.
Old Oct 3, 2003 | 05:49 AM
Dr. Evil's Avatar
Ya probably already know this but, You could get a Superchips programmer ($300) or other electronic speed corrector (not sure on price, I think around $100) to fool your ECM into thinking that you still have the stock tires on......
Old Oct 3, 2003 | 08:12 AM
Sawbones's Avatar
Mine is off by exactly 10%, so at 65 mp by speedo you're actually going 71.5
Old Oct 3, 2003 | 10:45 AM
ridofpwrstroke's Avatar
My superlift true speed says the difference between stock is about 200 rpms checked by gps. At 70 with the stock tires I would be at 2000r's. Now with the 315's, I go 78 at 2000r's.
Old Oct 11, 2003 | 07:11 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Yes the 3.77 effective ratio will give you a slower take-off, but might give you a slightly higher top end.
Old Oct 13, 2003 | 11:51 PM
Dr. Evil's Avatar
[quote author=LE link=board=7;threadid=20486;start=0#msg192162 date=1065151733]
The most accurate way to determine speed is to use a GPS unit. LE
[/quote]
I believe this is the most accurate answer......beg, steal, rent, or borrow a GPS and check it.
crater12
Dec 8, 2005 05:55 PM
t_george77
29
Nov 4, 2005 04:11 AM
Tiara3100
Sep 12, 2005 09:44 AM
rjordan
Sep 27, 2004 09:25 AM
kindog
Apr 30, 2004 06:24 PM
