Question fot the turbo GURUS
Old Sep 12, 2003 | 12:07 PM
hellotbone's Avatar
Here is a question I have always wondered. Say accellerating lightly up a large hill when my truck its od and is lugging say I get a really loud woosh sound from the turbo not the usual screm like when accellerating hard and it really sounds like its sucking like crazy however when the turbo does this the truck feels lazy. Anyone explain this to me?
Old Sep 12, 2003 | 12:42 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:Question fot the turbo GURUS
What you are describing sounds more like the when Clutch Fan kicks in.
Old Sep 12, 2003 | 01:22 PM
hellotbone's Avatar
It has that roar sound buts its not the fan the turbo makes a similar sound.
Old Sep 12, 2003 | 01:40 PM
Scotty's Avatar
Top's Younger Twin
Check your intercooler hoses and clamps...real close.
Clamps might appear to be tight but not.
Hoses can creep out from under the clamps too.
Hoses can have splits in them too.
How is the boost?
Old Sep 12, 2003 | 01:45 PM
hellotbone's Avatar
Boost is normal scotty. Thats what gets me its a totally differnet sound it has always done it so its odd
Old Sep 12, 2003 | 08:46 PM
Stamey's Avatar
I'm no expert here, but I'm gonna throw something out there. When the engine is "lugging", it is not able to consume all of the boost you are trying to put in there and the woosh you hear is the air being churned as the turbo tries to push it in but the engine can't take it all. At higher RPM the engine is able to absorb the additional air from the higher boost. This is less likely to happen, if at all, with a stock truck because it is not able to put enough fuel in there to get the turbo spinning fast enough to raise boost pressure higher than the engine can consume, even when lugging.
OK experts, what do you think?
Chris
Old Sep 13, 2003 | 08:31 AM
hellotbone's Avatar
Sounds logical to me.
Old Sep 13, 2003 | 09:02 AM
Diesel Freak's Avatar
The high boost/low rpm condition you are describing when lugging causes the turbo to run very close to surge. This is easier to do with your -40 than the stock HX35.
Running a turbo this close to surge won't hurt it, that is untill you quickly back out of the throttle....and then it starts Barking at you..then you run the risk of a broken turbo shaft.
I have heard this every time I do this on my truck, or Rips truck when out on a diagnostic run through the neighborhood.
CumminsRedneck
Jul 6, 2013 03:20 PM
John Faughn
Apr 9, 2006 02:04 PM
singleturnout
Jan 7, 2006 07:28 PM
ratsun
Dec 21, 2004 09:16 PM
turboblue
Nov 27, 2002 03:01 PM
