Quadzilla Adrenaline Tuning Help 99 24v
i have a 99 CTD 5 spd iam needing some custom tuning help. my settings are fuel surging my truck if i go above level 2. i have everything tuned very low. expert help needed.
I would recommend a few things.
1. research other threads regarding the ADR.
2. Quad has updated the tunes on there website as of 1/9/11 to eliminate the surging on the tunes.
3. What type of fuel LP do you have? How do you know you're not running out of fuel or possibly the filter is clogged.
Most of the people on DTR don't sit around their PC all day long waiting for threads to pop up and issues to be solved, be patient, there is a ton of great help here.
Just a couple of things to eliminate prior to moving fwd as it's a process of elimination.
well im not running out of fuel i can promise you that. ive got a fass 150 with new filters. also ive got aftermarket injectors. my timing is on 2.0 and everything else is just as low if not lower
The search function is your friend.
Your asking a question that has been asked to death.
Which tune are you running? That helps.
Does the Pulse and Ad both have all the latest updates on them?
I don't think your situation is unusual w/the "oddities" and mysterious events. High Idle has been my friend w/this cold weather and after it is engauged by the ADR and runs for a while the truck dies. It's happend both this week w/the #10018 & #10022 tunes.
When i use high idle in the summer for a long time the Pulse would go nutz with the read outs.
Now when pushing snow the Pulse goes goofy too. The other day the EGT's showed 640000 and the other 3 gauges said 0. Had to unplug the AD for it to reset.
Larry
mopar440cu
Nov 21, 2015 08:39 PM
Kurran
Apr 23, 2011 08:32 PM
Smokin98.5
0
May 29, 2008 05:35 PM
