quad and puck
Old Jul 28, 2007 | 10:49 PM
txsbigdaddy's Avatar
quad and puck
ok i think i hve decided to go with a 120 box from quad stacked with the puck what do yall think.
Old Jul 28, 2007 | 11:13 PM
dodgeguy71's Avatar
Don't want to rain on your parade Txs but what's your fuel pressure like with just your puck on there? I know mine gets pretty low with just the puck and I was thinking if you add that quad your gonna be dumping more fuel. Also, what about your clutch? I'm going for a set of 100hp nozzles on my truck and figure I'll need a FASS(more fuel flow/pressure) set up and not to long after that I'll be buying a clutch cause the stocker will be toast. I have not experienced it but what I have heard most people say the stock clutch barely holds stock hp.
The quad don't do anything with timing does it? If it just adds fuel cool, can't add timing I believe the puck does that already. Sounds pretty cool to me except your gonna have to be watchin your fuel pressure and clutch. Do you have a pyro on your truck?? Not sure I saw one in your sig. Before the puck my egt's would typically run 600 and on unloaded pulls up good size hills 800 and floor boarded maybe 850's. With my puck I can hit 1000 degrees pretty quickly so you'll have to consider what the qaud is gonna do to your egt's. You may end up needing more air, adjustable wastegate etc. Just some things to consider before you add that power and find out the clutch slips, your turbo is on the verge of a meltdown and you've got the towns fastest mosquito defense system.
Shawn
Old Jul 28, 2007 | 11:22 PM
im going to get a recon gauge and i have a holley blue in the shop but right now i can pull it down to about 8psi i just dont like the fact that the puck will not pull un till about 1800rpm oh yeah i think the truck must have a po clutch cause it is a stiff mother compared to my father in laws 2 other trucks both 99s
Old Jul 28, 2007 | 11:49 PM
dodgeguy71's Avatar
I'd get the pyro on there first and the holley. You'll be well into the 5psi zone with the quad. As I said, as long as the quad is a fueling module only you'll be alright cause your puck does timing. You may have to do some wastegate adjusting, but not to sure. I know I'll have to when I ad the nozzles on mine. You'll just have to watch your egt's and experiment and see.
Old Jul 29, 2007 | 12:19 AM
qzilla's Avatar
The box you are looking at will work perfect with the puck. You will want to keep an eye on the fuel pressure but, I think that goes without saying even on a stock truck. These lift pumps have a pretty bad rep to start with.
The box you are looking at is a fueling only box so you will be fine.
Old Jul 29, 2007 | 12:24 AM
thinks i made the decision after talking to rork (not sure on the spelling) for about 30 min on the phne and also after talking to jim in emory (which im only 30 min away from).
Old Jul 29, 2007 | 06:07 AM
wildwood2500's Avatar
Tsx your clutch will start screming at you, mine will slip with my mods and iam looking at geting a timing box to go with my XZT. i can pull my fuel pis from 25 down to 18 with rv275 and the xzt egt at 1100 to high 1200unloaded, loaded at will drop to 12, and 1300 and up loaded, so a better lift pump is and gauges are a must.
Old Jul 29, 2007 | 07:44 AM
ok how do i know if i have an up graded clutch as stated in an clearer post its pretty stiff.
Old Aug 1, 2007 | 10:33 PM
ok i got the 120 quad coming,a sumitt racing black,pyro and boost gauges on the way any thing else i need hahaha....
Old Aug 2, 2007 | 09:45 PM
ok im just going to cut a section out of the fuel line i need to know what size hose i need
tex23455
Feb 18, 2008 07:57 AM
BIGDAN65
16
Jan 23, 2008 10:02 PM
Stainless
Nov 1, 2007 10:53 PM
tex23455
Aug 21, 2007 10:43 PM
