pyro probe placment
Old Jan 13, 2005 | 03:11 PM
Turbo6guy's Avatar
pyro probe placment
Just got gauges for my '02 and was wondering about the exact placement of the pyro probe in the manifold. Thanks.
Old Jan 13, 2005 | 04:53 PM
RowJ's Avatar
Anywhere on the rear (back bumper) side of the manifold. There is a rib running full length, down middle of manifold. Since rear 3 cylinders may run warmer than front 3, you want to measure their EGT. Suspend end of probe into MID air stream. Away from any metal surface.
Not a great picture but...gives you an idea...
Good luck
RJ
Old Jan 13, 2005 | 05:48 PM
Moose10's Avatar
See my gallery
I will also suggest to step your drill bits out too if you hadn't already planned to do that....also nice & easy with the tap...back it out to clean the threads if there's a lot of buildup.
Old Jan 13, 2005 | 05:53 PM
rockwithjason's Avatar
My brother is an airframe mechanic. United teaches all of their mechanics to use at least two bits to drill cast. When you make the pilot hole small cracks develope around it. The second pass cuts away all of those cracks and minimizes the chance of a crack developing from the drilled hole. Just FYI
Old Jan 13, 2005 | 06:29 PM
Moose10's Avatar
Good to know....I had no idea...just knew it was easier and cleaner to step out the bits, than trying to jam the final size bit in a pilot hole.
Old Jan 13, 2005 | 11:52 PM
halerazor's Avatar
here is a diagram of where it should go
http://www.piersdiesel.com/TechPyroInstall.htm
Old Jan 14, 2005 | 09:47 AM
Turbo6guy's Avatar
Thanks for the info guys. Eric
Old Jan 14, 2005 | 09:54 AM
Turbo6guy's Avatar
My only other question is the difference between where RJ said and where Piers said is the proper placement, although they would both be measuring the back 3 cyl.So I'm guessing either one is fine. Or is it critical that the back 3 need to be monitered more?
Old Jan 14, 2005 | 10:06 AM
infidel's Avatar
It looks to me that RJ's and Piers are both in the same place.
Piers told me the back three cylinders run hotter on a 24 valve but on a 12 valve the front and back three are about the same.
Old Jan 14, 2005 | 10:23 AM
Turbo6guy's Avatar
OK Thanks!
Old Jan 14, 2005 | 11:31 AM
HOHN's Avatar
I followed the Piers instructions best I could.
Justin
Old Jan 14, 2005 | 12:18 PM
Turbo6guy's Avatar
Thanks Justin.
tomd
Dec 12, 2006 10:56 PM
DSjockey
May 15, 2005 09:46 PM
CTDCAL
Oct 23, 2003 12:09 AM
Sep 20, 2003 10:07 PM
TinJim
Apr 28, 2003 09:50 PM
