Pyro and FP Gauge Questions
I am thinking about adding a Pyro, Fuel Pressure, and Boost gauge. One major question I have is will installing a Pyro gauge void my powertrain warranty? I have an '01 with 67,000 miles and don't want to have the gauge install void the remaining warranty. I have a fairly stock truck...does it even make sense for me to install a pyro?
Also, where is the best place to connect the line from the fuel pressure gauge? The underside of the fuel filter cannister looks pretty tough to get to where as the line coming off of the VP is right their? At least I think it is the VP. It is to the right of the fuel filter and has a line running off of it right over to the fuel filter. I was thinking of removing the banjo bolt/fitting(?) with the black plastic cap screwed on it and replacing it with a tapped banjo bolt.....or could I just remove the black cap and work right from there?
I think I am going to go with Isspro gauges from Diesel Manor...unless anyone knows where I can find them cheaper?
I heard that if you install a pyro they will void. They will say metal shavings dropped in when you tapped the manifold.
As for fuel pressure i wouldn't see why that would void the warrenty but it may. I think the best place to hook it up is on top of the thing the filter goes to . I think there are 2 little 10mm or so bolts one is pre pump and one is after i am not sure which one you hook it too i am sure someone will know better.
dzl_damon
06-07-2009 06:28 PM
Mr. Jimmy
01-20-2006 03:51 PM
Igor
09-13-2005 12:47 AM
