Comp box....now what injectors?
What Injectors should I run with the Edge Comp Box? I don't tow a whole lot but when I do, its a heavy load. What injectors should I run? Opinions and experiences are good to hear about! Thanks guys,
Matt
Matt
CODODGE2500MAN,
That's a loaded question, it depends on how much HP you want to make. For customers that want a nice bump but don't want to go crazy we go with brand new Bosch 275 RV's. A good solid 65-75 HP and some smoke but not much. They are real resonable, they are new too and they are a simple install too. Call us if you need pricing or have questions etc.
Mark @ DPPI
Mark @ DPPI
What injectors are others running with the comp box? I'm not looking for huge numbers, and I want to keep the stock turbo. What would you suggest? RV 275's or........?
RV275's offer an awesome bang for the buck and are a great match with a Comp when using the stock turbo.....You will probably be able to tow heavy on the lower settings on the Comp with the RV275's. If you want a big hp jump, I would suggest a Mach 1.6. Though, you probably won't be able to tow heavy with the Comp turned on when running 1.6's with the stock turbo, they will still provide a huge power gain while still keeping egt's in check even without the Comp turned on......and when empty, the Comp and 1.6's will be about as powerful a combo you could run with the stock turbo - the truck will be down-right fast!!
bwarning01
15
Aug 24, 2007 09:19 PM
flinn101
Dec 14, 2005 09:45 PM
flinn101
14
Dec 14, 2005 09:43 PM
Buz
Mar 28, 2005 04:17 PM
hellotbone
Jul 12, 2003 12:58 AM
