pushing the limit
Old Jan 22, 2007 | 07:50 PM
  #31
01smokin's Avatar
40miles west of st louls
Old Jan 22, 2007 | 07:55 PM
  #32
blackdiesel's Avatar
Registered
im in arkansas, right across the line from MO. i dont know anyone from your area, but check out the missouri dtr chapter. aka modtr 30
Old Jan 22, 2007 | 08:03 PM
  #33
01smokin's Avatar
i got a guy who has a peformance shop and he is going 2 get me everything at cost minus the sticks and converson kit
Old Jan 22, 2007 | 08:08 PM
  #34
01smokin's Avatar
what would u compair the aurora compound 2
Old Jan 22, 2007 | 08:13 PM
  #35
BCB's Avatar
BCB
not to hijack but... what will a HX40/ S400 cool and what will a 62/14 s400 and a 64/14 s400 cool in a 12v with a studded, oringed and ported head?
Old Jan 22, 2007 | 08:25 PM
  #36
mysterync's Avatar
the ats compounds are out by themselves, there a good setup but ive never seen one in action! as far as what the setups will cool , it depends on the truck, timing, exhaust, who built them and so on, i would feel that a 64 over s400 will cool 700 fairly well! the 40 is a good charger and there's some running a 40 over a 3b but im not sure on cooling, i would think the 62 over s400 would cool a little bit less than the 64 but there efficent well over 600 if i remember right, atleast high 600
Old Jan 22, 2007 | 08:35 PM
  #37
01smokin's Avatar
the ats flows1708 what would thoes setups flow do u know
Old Jan 23, 2007 | 05:05 AM
  #38
cmpunch's Avatar
01 if you would like to talk to a guy that has built a 500hp very streetable p-pump truck and has played alot with these you might want to pm RonA .
Old Jan 23, 2007 | 07:45 AM
  #39
getblown5.9's Avatar
mysterync, im a scavenger...if you go to the super hot 7's what are you doing with the 6's?
Old Jan 23, 2007 | 02:40 PM
  #40
kelownadiesel's Avatar
Man if youre serious I would simply sell the 24v truck and buy a 12v truck.You will be ahead in dollars from the get go,plus no messing around with conversion kits,plus the injectors are cheaper.If you want big p pump hp you will have to run a valet switch and an expensive built pump either way.
Old Jan 23, 2007 | 03:10 PM
  #41
Morse's Avatar
I used to have my pro street engine in a daily driver dually. It was a 13mm race pump, SPS66/big brother twin setup. It ran Dynomite Diesel 4's. It was very streetable even for an automatic. Just a light haze of smoke at wide open throttle, and very little lag.. If the combination is right, a p-pump big twins combo can be great.. Olee built the tubing, and the twins are from II.. After that was working perfect for weeks, I decided to do a lot more mods, and put the engine in a half ton. So far the truck has never run well again.. It's at Garmons now, for lots of work and the ac is being re-installed..
Old Jan 23, 2007 | 04:53 PM
  #42
mysterync's Avatar
Yup , thoses 6's will be for sale ! Ill put it on here! Im just saying on the idea of Converting from a vp44 to a p7100 its not for the shallow pocketed! I wasnt trying to say it wasnt possible!
Old Jan 23, 2007 | 08:05 PM
  #43
01smokin's Avatar
u guts might have convinced how do i get 500 out of a vp44
Old Jan 23, 2007 | 08:23 PM
  #44
mysterync's Avatar
I make 595 on #2 only with just a set of mach 6's-oring-studs-sps66-drag comp-fass pump.
Old Jan 23, 2007 | 08:29 PM
  #45
you want 500 exactly...see my sig
