Push Button Shift Lever
Old Mar 9, 2008 | 09:47 AM
WVAussie's Avatar
I remember seeing a shift lever with a push button in the **** some where but can't find it now. Anybody know where to find it? I see that Geno's has just the **** but I'm sure somewhere had the whole lever.
Old Mar 9, 2008 | 12:44 PM
DodgeCowboy's Avatar
DTR's Cow Boss
here ya go bud there at genos What are you going too use it for?
http://www.genosgarage.com/prodinfo.asp?number=EKNOB
Old Mar 9, 2008 | 01:40 PM
WVAussie's Avatar
Yea i saw those, I was looking the whole lever. I am wanting to use it for a mystery switch.
Old Mar 9, 2008 | 03:40 PM
DTR's Cow Boss
Lever as in hi and low gears in a eaton shifter? you might have too look around salvage yards that deal with big rigs.
Old Mar 9, 2008 | 05:31 PM
WVAussie's Avatar
Maybe I have it wrong but I seem to remember that someone replaced the complete gear shift lever with one that had a switch in the end.
Old Mar 9, 2008 | 06:02 PM
camelracer's Avatar
I have the Geno's shift **** with the switch and it works great for the PAC brake. I see no reason to replace the whole shifter to get the switch. It was an easy install.
Old Mar 9, 2008 | 09:29 PM
WVAussie's Avatar
I would like to use the Genos **** but The end is moulded to the lever on my truck or at least I'm pretty sure it is, and Genos is a screw on right?
Old Mar 9, 2008 | 09:46 PM
marine4life's Avatar
Nah, it should screw off, it's just on there pretty tight. All dodges manuals ***** come off.
Old Mar 9, 2008 | 09:58 PM
camelracer's Avatar
Pry up the shift pattern button and you will find a nut that holds the **** on.
Old Mar 9, 2008 | 10:16 PM
WVAussie's Avatar
Man I haven't been clear. My truck is an auto.
Old Mar 10, 2008 | 06:40 AM
Valv's Avatar
Does your shift lever had the O/D switch built in ?
I never had a 12v auto so I cannot tell, but if you don't have it you can use a '99 and up shift lever, they have a switch at end of lever to turn on or off the O/D in the transmission when towing heavy.
Is this what you are looking for ?
Old Mar 10, 2008 | 07:07 AM
WVAussie's Avatar
Thats what I want. Do you know if they are a easy replacement or do they have to be modified. Ive been trying to find this shift lever this morning on parts sites with no luck.
Old Mar 10, 2008 | 07:11 AM
91rangerturbo's Avatar
i thought that was stock on 12v trucks. Mine 99 24V has a O/D button on the factory shifter. And i think the only replacement would be a toggle or push button switch.
You could always use a floor mount dimmer style switch like in older ford trucks and mount it in the floorboard.
Old Mar 10, 2008 | 07:14 AM
WVAussie's Avatar
96 has no button in the lever. I plan to use a dimmer on the floor for an exhaust brake. I hate having add on switches in the dash.
Old Mar 10, 2008 | 07:33 AM
BC847's Avatar
1st Generation Admin
You talking about this? . . . . https://www.dieseltruckresource.com/...d.php?t=173561
