pump tap problems on adrenaline
Old Feb 21, 2009 | 10:14 PM
psd tuner's Avatar
i have the problem of the tap having a bad connection. the wire is plugged in but the problem resides in that little t-tap thing qzilla sent. would it be better to maybe soldering the wire on there and putting a peice of heat shrink to insulate it. what do yall think...would it work good like that or do i need to take off the t-tap and move it on a different spot on the wire???
Old Feb 21, 2009 | 10:40 PM
J Lent's Avatar
I would just use a stealth cover.
Old Feb 22, 2009 | 02:43 PM
psd tuner's Avatar
stealth cover??? i am gonna have to search the internet for that. had heard my friends talk about it but never seen one.
Old Feb 22, 2009 | 02:47 PM
93John's Avatar
Stealth cover is your best option. Did that to my buddys 00, plus the new pump stays under waranty. Xtreme diesel has them.
Old Feb 23, 2009 | 12:20 AM
LucasB's Avatar
BD makes one and so does Blue Chip
Old Feb 23, 2009 | 02:57 AM
Fishin2Deep4U's Avatar
Soldering the wire is the best solution. It's easiest to remove a small piece of insulation on the pump wire, plunge a small "tap" wire in and solder. Finish with 2 coats of liquid electrical tape and wrap with some friction tape or a piece a small loom for abrasion resistance.
The stealth covers work, but they have been the cause of more than one cracked circuit board and if they build up any corrosion, they will hamper performance. We added 50HP to a truck by removing the cover and going to a soldered connection.
Dave
Old Feb 23, 2009 | 03:24 AM
Erska's Avatar
Can you describe what are your symptoms? Do you get a check engine light and a shuddering boost for a second when the fuel stretch takes its place?
LovinTheTorque
Sep 14, 2013 12:02 PM
glarior
May 17, 2011 07:46 PM
alto22
34
Feb 16, 2007 09:28 PM
Hoss
Apr 11, 2006 11:37 PM
bgilbert
Mar 2, 2006 04:01 PM
