pulse water temp ?
pulse water temp ?
My adrenaline pulse will go to 0 when it gets to 205 degrees water temp. The moment it goes to 204 it will read fine again. Just me or some other problem with the truck?
Mine did that once this summer as well while pulling a trailer up a hill. It actually cut the box back to 0 and then went back to normal. I did not think too much of it.
What water temps are you guys seeing while daily driving and towing? Daily driving mine stays between 188 and 195. Towing its normally 195-197 any maybe a little higher pulling up a hill. Just wanted to make sure thats normal.
I've been grossing from 12,000 up to around 32,000 the last few days. My temp runs around 200 loaded but goes higher taking off with a load. I was grossing a hair under 30,000 tonight with the outside temps at around 60 degrees. Last night was alot warmer and bigger load at dare I say 33,000 and it run over 200 all the way. Taking off is the real heat builder, once the convertor locks it cools right down on the flats. I usually pull these kind of loads with od. locked out.
95ram
Feb 6, 2009 05:30 PM
fitzer
Jan 31, 2004 11:20 PM
