Propane tanks
Old Oct 26, 2003 | 06:39 PM
LanceD's Avatar
Propane tanks
I found some tanks at Tractor supply today that ranged from 30# to 100# tanks and it said they are DOT approved but there is only one valve on top like the BBQ grille tanks. can these tanks be mounted sideways? do I need a tank that has both valves?
thanks!
Old Oct 26, 2003 | 06:56 PM
acoustic_axe's Avatar
Re:Propane tanks
I think ya can, couple problems i see are at from full to 1/2 you'll get liquid, after that vapor.
Only one valve could be a problem, if you want only vapor out of it or liquid only. Not sure on the wall thickness, but i bet they are not as thick as one built for truck use. 60 gallon saddle tank i have is pretty heavy.
Old Oct 27, 2003 | 04:32 AM
y-knot's Avatar
Re:Propane tanks
I think you will find that the DOT aproved stamp is for transport use only.
Old Oct 27, 2003 | 06:14 PM
Re:Propane tanks
What you need is a propane tank like is mounted under the floor of an RV. Try an RV dealership, just don't tell 'em what it's for. :-X
Old Oct 27, 2003 | 06:17 PM
Suburbanite's Avatar
Muted User
Re:Propane tanks
You can also find used tanks at salvage yards & propane suppliers.
Good luck.
Old Oct 27, 2003 | 10:11 PM
Helicopter Dan's Avatar
Re:Propane tanks
go to your local propane distributer and get a propane tank for a forklift those work on their side
Flatbed24v
Jul 31, 2009 10:57 AM
ocsurf16
Sep 25, 2006 10:36 AM
PowerDually
Jun 12, 2005 10:51 AM
moss2904
13
Mar 24, 2003 02:36 PM
