Programmers ???? Best MPG
Old Aug 30, 2006 | 05:38 PM
qwest's Avatar
I only want MPG, Which is better????
And, Do any makes allow defeat of the 'Can't Stall' feature,?
Old Aug 30, 2006 | 07:16 PM
CTD2001's Avatar
Well i installed a Diablo Power puck on my fathers 2002 H.O. 6speed 4x4 about 2 months ago and he hand calculated over 21 mile per gallon, which netted him an extra 50 miles per tank. He can now go over 600 miles on a single tank of fuel. Plus the truck has more power which he likes.
Not to sure what you mean by the Cant stall feature??
Old Aug 30, 2006 | 08:51 PM
duallydave's Avatar
Talking
for some wierd reason im getting better mpg on setting 9 than the fuel saver mode on the smarty,ive gained 2 mpg maybe 3 if i drive easy,and the power increase was awsome,i dont know of anything that disables the cant stall feature,i think its there to help the engine,it may be hard on it to lug it so low that it stalls.theres a used smarty in the classifieds here,you wont be disapointed with one,
Old Aug 30, 2006 | 10:13 PM
dieselfan's Avatar
how many tanks did you run with each one. did you get worst mpg on fuelsaver b\c you stayed in the throttle more. any info is appericated, my smarty should be in tommorow or friday. thanks dieselfan
Old Aug 31, 2006 | 09:05 PM
duallydave's Avatar
Talking
i went thru about 2 maybe 3 tanks on fuel saver mode and wasnt on the throttle any more than normal,i really wanted to save fuel so i was even easier than normal driving,i really havent experimented much with many settings besides fuel saver and 8 with my comp and 9 with no comp,i havent even tried the others,with the smarty on 8 and the comp on 3/3 was pretty good mpg with wicked power but on smarty 9 and no comp with my injectors im seeing excelent milage,almost as good as my old 12 valve,i can almost see 650 miles per tank,thats driving pretty easy though.the old egg under the pedal trick.
Old Aug 31, 2006 | 09:14 PM
dieselfan's Avatar
thanks duallydave, thats just what i wanted to know. hopefully my smarty will be in tommorrow.
thanks again, dieselfan
kubotawayne
Mar 8, 2016 05:59 PM
cumminsdriver635
May 19, 2008 10:44 AM
usmarinetx
Feb 11, 2007 08:10 AM
LooseBoltsRob
Sep 25, 2006 05:51 PM
Rocket95
Feb 22, 2004 06:54 PM
