Problems with DiPricol FP gauge
Well, the gauge is about 5 months old, and with in the past two weeks the gauge has developed a real loud anoyoing rattling noise and the needle vibrates severely and jumps around alot when i hit a bump. The gauge is mounted on the steering column. I took the gauge out of the pod to see if there was anything visible, but the rattling is without a doubt coming from inside of the gauge itself. Has anyone had a problem like this before with their gauge? Would it be worth taking the gauge apart? Does anyone know what kind of warrenty come with these gauges, Thanks for the help
Originally Posted by CTD2001
The fuel goes straight to the gauge. If i put a needle valve on, and just crack it open, will that eliminate the buzzing noise?
I had the same problem thought it was the gauge let it go for a couple months until i got smart and did a search on this site and realized i needed a needle valve.$5 at home depot and it fixed the problem.
Great, is that the part number i give them at Napa? That is just what i need, Thanks
Take another look...
But yeah that number applies to a WeatherHead Valve...
Originally Posted by Captain
do you put the valve between the source and isolateor or between the isolator and gauge? and wont opening it slightly allow the fluid to come out?
But if you were going to use the valve with a isolator you would put the valve before the isolator on the fuel side. Then just open the valve a good turn or two. Being the isolator would do the suppressing of the pulses but the valve would allow you to shutdown in a failure. (Which is happen with the isolators that I've heard).
