Problem with power numbers
Old Jul 25, 2005 | 07:40 AM
BigBlue's Avatar
I put my truck on the rollers this saturday and needless to say I was a little disappointed. I put down 260hp and 600tq. This was on a dyno jet. I dynoed in OD per the operators instructions and started the run at about 65mph and shut it off somewhere around 110mph. The temp was 104* and I'm sure the humidity was just as high. My comp is in EZ mode. What could the problem be? Maybe the comp isn't working quite right? Any help would be greatly appreciated. Thanks for the help yall.
Old Jul 25, 2005 | 07:42 AM
BigBlue's Avatar
Just went out and checked the part numbers off the injector boxes and they say 0 432 193 635 and then there's a -825 real small on the right hand side of those numbers so it reads like 0 432 193 635-825. Is that the right number for the 275 injectors?
Old Jul 25, 2005 | 07:44 AM
signature600's Avatar
What's wrong with your numbers??? Seem fine to me for an EZ on a slushbox!
Chris
ON EDIT: Didn't see the 275's in your sig...maybe something is a little off
Old Jul 25, 2005 | 11:51 AM
RowJ's Avatar
Big Blue
Checked my old dyno sheets.
With an EZ, Mach 1.5's (85 hp), I made 269 HP
Added a KSB-1B and went to three runs between 289 hp and 298 hp
These runs were early AM with OAT at 79*. A lot of guys had low numbers on Saturday....over 100* has to make a big difference. I did not here anyone who got their best readings ever!
Hope these numbers help you.
RJ
Old Jul 25, 2005 | 12:52 PM
gunracer1's Avatar
i was suprised that my tubo didn't start building boost till 90 mph, and it was a all but smoke free run. i have never seen a 400 plus run with less smoke unless someone was shooting nos. and my buddies truck, [BBWD] i thought would have been in the 350 range did 304 but o well. i had a blast and enjoyed bsing with everyone.
Old Jul 25, 2005 | 01:00 PM
BigBlue's Avatar
Hmm. Rjohnson, maybe my numbers weren't to far off then. I'll agree that the conditions were less than ideal but I figured I'd do a little better. Oh well. Hopefully in october I'll have a few more to bring to the table.
Old Jul 25, 2005 | 03:27 PM
GlennRMK's Avatar
Your #s are low, because you are in OD! Never heard of dynoing in OD.
Every dyno I see is always in 1:1 gear(3rd in your case).
OD is .7 the power that there is in 3rd.
I'd say your closer 325 hp and 750 ft lbs
Old Jul 25, 2005 | 03:32 PM
RowJ's Avatar
Originally posted by GlennRMK
Your #s are low, because you are in OD! Never heard of dynoing in OD. ...the power that there is in 3rd.
Can't speak for anything but my set up...but I had heard this when I started dynoing. Did first 3 dynos in third...always came out lower than others with same mods!
I switched to dynoing in OD...got much better numbers!
RJ
Old Jul 25, 2005 | 03:36 PM
GlennRMK's Avatar
Maybe you can't spool all the way up in 3rd, but I don't see why? I redline 5th(1:1) in my truck at 85 MPH. Should be plenty of speed to build power and boost.
Maybe I'm wrong. But I have always seen dyno #s in 1:1 gear
Also, redline in top gear(OD) would be 120 MPH and 135 MPH for BigBlue with 35" tires!
110 MPH for Big Blue is only 2600 RPM!
Old Jul 25, 2005 | 03:46 PM
RowJ's Avatar
Why would you care/want to dyno at redline?
Mine dyno graph, in OD, hit max HP at around 2550 rpm and table topped all the way to PM3 reduced fueling at 3200 rpm.
Torque dropped off steadily from 2700 to 3200 rpm.
I agree Big Blue would dyno better with smaller tires.
RJ
Old Jul 25, 2005 | 03:50 PM
GlennRMK's Avatar
Depends on the truck. In your case no.
But I would think with a COMP you would make power higher in the RPM range. But could be wrong.
Still, you have less mechanical advantage with lower numerically gears.
Identical trucks, one with 3.55s and one with 4.10s, the 4.10 geared truck should dyno higher. That is why you should dyno higher in 3rd then 4th.
Maybe I will have to dyno my truck to find out what the deal is
Old Jul 25, 2005 | 08:02 PM
BigBlue's Avatar
Actually, the 4.10 truck would dyno lower.
Old Jul 25, 2005 | 10:14 PM
fordsux8269's Avatar
Whenever I do a run in 3rd with the tc locked I can only build 28psi but whe in od I can build 38 easy
Old Jul 26, 2005 | 07:21 AM
lsgibb's Avatar
I'd say your numbers are low, in May here in Boise I put down 252hp and 640tq (uncorrected) on a dynojet with just a power puck and a Stage 2 intake. Granted the conditions were ideal low 50's and it had just finished raining so there was plenty of moisture in the air. This was with an HO in 6th gear all the way to redline at 125-130 mph.
sCreamin400
Nov 2, 2008 01:46 PM
derherr65
Nov 17, 2006 02:08 PM
king d
Jun 5, 2005 06:26 AM
03CTDCO
Jan 4, 2004 10:17 PM
