Power Question on 12v
Old Apr 21, 2004 | 01:08 PM
mysterync's Avatar
Hey guys, First of all ill let you know what my setup is!
Ive got a 95 3500 5spd
I'm running a number 8 plate
BD Hx-40 with bd turbo guard
4 inch to 5 inch straight pipe.
SB 13-1.25 Con OFE
And 370's
I was wondering , I know they say a hx 40 can make upto about 400-450 . What would need to do to get it. or atleast what plate is going to push the hx40 and head gaskets limits
Thanks for any help
Lucas
Old Apr 21, 2004 | 01:56 PM
signature600's Avatar
I would think your close to pushing those ponies and limits, but I'm far from an expert.
I have the #8 slid about 1/3 forward and I can hit 36-38 psi anytime I want, and you've got injectors. I think that pushing the stock head gasket limits are about 45 psi, but I want it to live through it. I've heard they're good for 50-55 sometimes.
BTY, Did you notice any change in putting on the Banks Intake (Twin Ram, I assume)? I've heard they make a noticeable change, but I can't see spending the cash for one.
Take it for what it's worth,
Chris
Old Apr 21, 2004 | 02:26 PM
mysterync's Avatar
Chris,
i didnt own the truck when it was put on. I know im seeing lots lower egts than most other truck same setup without it, It look good and i really belive it makes a diffrence in the truck, maybe not so much at the low end of bombing, but now that im getting into alot of fuel and air, i feel like it makes a big diffrence. The downside is!!!! I've been through 4 fuel line holders for the back half of the manifold and 2 lines because of it, There just so hard to get tight and keep tight!
Secondly , The gaskets , God forbid they go bad , very agrevating to get a gasket in there that will hold!
I was thinking about pushing my luck with a number 5 and keep it in stock post. Im running my 8 all the way up!
Thanks
Lucas
Old Apr 21, 2004 | 04:42 PM
infidel's Avatar
You'll probaby gain some hp and lower your egts by just sliding the #8 back a little. Full forward isn't the way to go.
Old Apr 21, 2004 | 05:06 PM
What kind of EGT's are you seeing, also What boost are you seeing?
My EGT's are 1200 TOPS, that is at 85+ before it defuels, most I see towing are 1000-1100 if I push it to keep 70+ on the hills at 20K+. SO, I can keep them in check and pull basically anything I want.
Old Apr 21, 2004 | 06:38 PM
mysterync's Avatar
I'm getting about 900PreT hard empty run without the 370's
And about 36-40lb empty as well.
I was thinking about going to a free flow boost elbo since the turbo isnt going to hold up above 40 lb.
How far should i slide that plate back?
Thanks
Lucas
Old Apr 21, 2004 | 06:39 PM
infidel's Avatar
At least .01 - .05
Old Apr 22, 2004 | 12:30 AM
VinDiesel's Avatar
Lucas,
Here's my $.02 on what to do next-
3K governor spring kit. You won't believe what a difference it will make, even with your current plate. Much more responsive throttle at all engine speeds.
Consider a #10 plate. When slid forward a little, it becomes almost equal to a #4, but with smoother delivery. Do a search for further discussion on it a while back.
Old Apr 22, 2004 | 05:54 AM
Jim Fulmer's Avatar
I totally agree with Vin Diesel here, now click the back button and read the thread about T/Q plate for a new beginner, there is some good info there.
Jim
Russell_d
Feb 25, 2007 09:12 AM
CTD2001
Feb 3, 2007 01:30 PM
apache
Oct 27, 2004 08:53 AM
Contractor
Oct 12, 2003 09:56 PM
