Please identify this HX40
Old May 5, 2005 | 10:53 PM
Bobcat698's Avatar
Its a Holset HX40.. has the following numbers on it:
Holset USA 3532859-02
19
24-01-210
Someone says it probably has a 19cm housing.. I know its wastegated..
I can get it for a good price.. Do you think I'll have problems spooling it with injectors a little bit larger than 370's?
Let me know what you guys think.
Thanks!
Old May 5, 2005 | 11:20 PM
Forrest Nearing's Avatar
you don't want a 19cm housing!!!!
more importantly, post up some pics of the compressor wheel... you can change a turbine housing... compressor side is much more difficult
Forrest
Old May 5, 2005 | 11:56 PM
Bobcat698's Avatar
Old May 6, 2005 | 01:09 AM
pass on it... you want the 6 blade compressor wheel
Old May 6, 2005 | 05:22 AM
PourinDiesel's Avatar
Wrong turbine housing too.
It wont mount up to a standard manifold (or at least it looks like the wider version).
Old May 6, 2005 | 09:15 AM
well, it's a 19cm housing, so that's a moot point... even if it would bolt up, you wouldn't use it
Old May 6, 2005 | 11:05 AM
Bobcat698's Avatar
What is wrong with the 8 blade design?
I have a 16cm wastegated housing possibly on the line.
Also, this turbo is brand new and would be a reasonable price...
Should I buy it or look at a HX35 hybrid from HTT or Piers?
Old May 6, 2005 | 05:09 PM
what diameter is that compressor wheel?
I'm guessing it's in the 57-58mm range?
it's just not worth the money IMHO
you want a 60+mm 6 blade wheel. that's the wheel that all the aftermarket companies use in their HX40's and hybrids...
Forrest
Old May 6, 2005 | 05:42 PM
signature600's Avatar
I've got one here that's got a 56mm wheel (8 blade) and an 18cm wastegated housing...I was gonna bolt it up but it also uses that T4 flange.
It will be on a trip to Piers shortly along with two over stressed 35's.
Hopefully this B1 I have can hold up to the punishment
Anyone think I'll have problems spooling a full-on B1?? Taking bets!
Chris
VikingDiesel
29
Jun 27, 2007 02:55 AM
smokeum99ta
15
Mar 10, 2007 04:11 PM
nobody
14
Aug 21, 2006 05:20 PM
barn6720
Mar 30, 2006 12:04 AM
Hawkeye
Sep 23, 2003 08:22 PM
