........piggy backing chips..........
Old Feb 24, 2013 | 10:10 PM
oldkimmer's Avatar
..........I have a 2001 cummins with upgraded tranny, 4 in exhaust and an Edge EZ........i can get an older VanAiken box part # CPC ISB 215.235...........i know they both add timing, but will both together add too much timing, and how do u know how much is too much and can i check timing with a scanner....the EZ uses the map sensor connection and the VA plugs in at the vp.....thanks......kim....
Old Feb 24, 2013 | 10:43 PM
06RAM2500's Avatar
Too much is bad.
Old Feb 24, 2013 | 11:51 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
You can't stack pressure boxes together, you can only stack a box with a programmer.
Old Feb 25, 2013 | 12:22 AM
oldkimmer's Avatar
..........Thanks guys.................kim...
Old Mar 19, 2013 | 09:47 PM
HOHN's Avatar
No such thing as a "pressure' box for an '01, Larry
Old Mar 20, 2013 | 01:32 PM
Admin Team Leader
Correct thanks for the help What I meant was you can only stack a box with a programmer, you can't stack two boxes together
lumberman
Aug 18, 2008 08:08 PM
052500#1
Jan 11, 2005 04:09 PM
kandgo
Nov 16, 2004 08:26 AM
PADZZ
May 24, 2004 08:02 PM
