Piers boost bolt
Old May 7, 2003 | 08:43 AM
TinJim's Avatar
Piers boost bolt
Trying to install my Di-pricol boost gauge using a Piers boost bolt and have run into a small problem. My boost gauge came with a 1/8 MPT male fitting and the Piers boost bolt I think accepts a 1/8 FPT male fitting. Is there a single adapter that will work or what assembly of fittings is needed. Hopefully I have described the situation correctly as my knowledge of pipe fittings is limited. Thanks.
Old May 7, 2003 | 08:53 AM
GrandpasRam's Avatar
Re:Piers boost bolt
I had to buy an adapter at my local NAPA. I think the Piers bolt took a 3/16" NPT, while the boost kit was 1/8 NPT (mine is an ISSPRO, but they should be the same I think). I took the Piers bolt with me, along with the boost fitting that would connect to it, and the guy found the fitting right away. I had tried Home Depot, then Ace hardware, then O'Reilly, but finally found it at the NAPA store. HTH.
Old May 7, 2003 | 08:57 AM
TinJim's Avatar
Re:Piers boost bolt
Thanks for that excellent tip. Have a close NAPA store. Will also take my fittings there and have them set me up with that adapter you mentioned.
Old May 7, 2003 | 09:50 AM
Re:Piers boost bolt
Glad I was able to help. That extra running around trip is part of what took me all day when I installed my guages. I thought I had gotten everything I needed the day before, but somehow missed that one, and all the different places I had to go to cost me 2 1/2 hours of errand. Hope I saved you that same.
Old May 7, 2003 | 10:27 AM
BigBlue's Avatar
Re:Piers boost bolt
Try a plumbing store. Since those are Pipe threads, a plmubing store will most certaintly have them. That's where I've gotten all of my fittings and adapters.
Old May 7, 2003 | 10:37 AM
Redleg's Avatar
Re:Piers boost bolt
Got mine at ACE.
FordTrax
Apr 18, 2014 08:47 PM
moparmatt
Apr 25, 2007 02:13 PM
043500QC
Dec 1, 2005 01:53 PM
drawson
29
Mar 26, 2003 10:48 PM
