Pick-up modification question.
Tomorrow I'm going to be digging into the tank module to modify the pick-up and rollover valve. Someone said on another site that the pick-up screen is not necessary. Can someone enlighten me as to why not?
Anybody got any last minute tips??? I'm looking at enlarging it to 1/2" and maintaining the spring action of the stock setup.
If I don't get too frustrated, I'll make sure I take some good pics!
I dropped the tank and found my module covered in rust! The screws on the side had worn through the upper portion of the module. The fuel line fitting protruding from the top of the module is steel and is rusted also ... looks like a new module for me!
I ended up getting a new module. Dodge had one they had used to diagnose another truck, which they were keeping "for shop use only." Instead of charging me $409 plus tax, I got it for $269 plus tax ... not a bad deal!
This one is completely plastic, so no more rust! The pick-up is 1/2" too, although it drops to 3/8" when it exits the module. I didn't see any change in fuel pressure, other than my pressure being steady again. I was having trouble with a vacuum in the tank, which is gone, since the new rollover valve is much larger than the old and actually works! I've got a lot of pics of the old module if anyone needs them for troubleshooting!
Cheers,
Andrew
Cheers,
Andrew
Originally Posted by gmctd
Hey, rj - check sig in third post from top, or maybe this one, if I'm lucky.
Don't 'zactly know what's going on, here - sometimes sig is there, sometimes not
FIRECAT7000
Feb 1, 2007 03:35 PM
D.Wiggs
19
Jan 4, 2007 12:39 PM
D.Wiggs
44
Oct 31, 2006 11:00 PM
j28s
Sep 23, 2004 02:27 PM
