performance help
Old Oct 22, 2012 | 07:28 PM
papajoeky's Avatar
performance help
I have a 1999 2500. Had an aftermarket holset turbo and bullydog lift pump when i bought it. I have added a 4 inch exhaust, edge juice with attitude, trans rebuild with torque converter and shift kit. I am not getting the performance that everyone tells me I should get and I am not getting the fuel mileage either. I am considering a set of injectors but I would like advice first. Any help would be appreciated.
Old Oct 23, 2012 | 06:21 AM
high bid's Avatar
Clean air filter....? Quality injectors such as formula Mach 1 or DDP will help but it's the combination of all quality components that help increase mpg. Might want to ck the easy things first, tire psi, easy on the right foot, and the clean air filter.
Old Oct 23, 2012 | 09:00 AM
mgdoug3's Avatar
What turbo was put on? HX35,40, 50, 55? Your problem could lie in the turbo.
Old Oct 23, 2012 | 11:08 AM
AggieJustin's Avatar
Also, what kind of performance and fuel mileage are people telling you that you should be getting? I've seen some outrageous claims when it comes to HP and fuel mileage numbers, just need to make sure you're not chasing unreachable values at your level.
Old Oct 29, 2012 | 06:45 PM
papajoeky's Avatar
Turns out it is a stock turbo as I thought. The guy who told me it was aftermarket was incorrect. I am getting about 11-13 mpg. Was hoping for around 18+. I had a dodge mechanic drive it and he thinks it is lacking power. I am leaning towards injectors next.
Old Oct 29, 2012 | 06:48 PM
mgdoug3's Avatar
What's your fuel pressure reading?
Old Oct 29, 2012 | 06:57 PM
papajoeky's Avatar
Old Oct 29, 2012 | 07:24 PM
mgdoug3's Avatar
Just a thought. Maybe by aftermarket turbo the previous owner meant he switched the turbo from a hy35 to a hx35. On a different note, I would think that with what you have fueling wise, you should be able to hit around 30+ lbs of boost. Anything below 25, I would look for a boost leak or some way to adjust the wastegate.
Old Oct 29, 2012 | 07:49 PM
papajoeky's Avatar
I am getting up to 29 on boost but i dont get into it that deep very often
Old Oct 29, 2012 | 08:28 PM
mgdoug3's Avatar
I'm puzzled then. You have fuel pressure and decent boost. You might be on the right path with injectors. Sorry I can't be much help.
Old Nov 5, 2012 | 09:23 PM
bigsmokey's Avatar
You have something wrong cause I have an 01 with almost all the same stuff and I get like 15 to 16 mpg city and 20 highway your injection pump might be on its way out
Old Nov 9, 2012 | 11:52 PM
oldkimmer's Avatar
..........have ur valves adjusted........kim.....
dslpwr81
44
Jan 13, 2006 11:32 PM
bbhzx12
Nov 11, 2005 09:13 AM
SilverHoss99
Oct 10, 2005 04:33 PM
genros
May 8, 2005 07:28 AM
jeepfun
Jan 14, 2005 03:49 PM
